GPS problem with RR running as shell
With the help of this guide I was able to boot directly into Road Runner. Everything seemed to be working fine till I opened GPS and found out that for some reason GPS is not locking to any settelites. So I imported the orignal registry (with Explorer as shell) file and restarted the computer and everything started working again.
What could be the connection between GPS unit and explorer ? that it does not work when window boots directly to frontend ?
Any idea ?
Update: It seems like Xport is the cause of the problem. When RR loads as shell, Xport does not run. But then when I manually run it, GPS starts working.
How do I make it load automatically with RR ? Also, when using RR as shell, how can I get rid of RR splash screen ?
