Results 1 to 9 of 9
Thread: GPS problem with RR running as shell
    Sep 2006
    Richmond, Tx: USA
    With the help of this guide I was able to boot directly into Road Runner. Everything seemed to be working fine till I opened GPS and found out that for some reason GPS is not locking to any settelites. So I imported the orignal registry (with Explorer as shell) file and restarted the computer and everything started working again.
    What could be the connection between GPS unit and explorer ? that it does not work when window boots directly to frontend ?
    Any idea ?
    Update: It seems like Xport is the cause of the problem. When RR loads as shell, Xport does not run. But then when I manually run it, GPS starts working.
    How do I make it load automatically with RR ? Also, when using RR as shell, how can I get rid of RR splash screen ?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    When running RR as shell you need to start Xport3 from the start command in RRConfig.exe.
    RUN;C:\Program Files\Road Runner\Xport\Xport3.exe or where ever your Xport3.exe file is located.
    To get rid of the splash you have to start RR with the /p switch.
    Sep 2006
    Richmond, Tx: USA
    Thanks, I'll try that out
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by MGD View Post
    Try /q instead...as in quiet startup, don't know what /p gives ya...problems maybe...lol
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You're right. Guess I was writing in mirror image.
    Sep 2006
    Richmond, Tx: USA
    Where do I enter this ? In RRConfig ? Also is it ";" or ":" ?
    Low Bitrate Cali's Avatar
    Apr 2006
    CA
    Just wanted to say thanks for asking this question... I had the same results and knew it was xport, but didn't find the time to research it yet (and knew I was still tinkering a lot within the OS.) anyway.. now I have my answer.
    Cali
    02 Corvette Z06
    CarPC: 8" Zenarc molded in dash, P3 1Ghz CPU in custom Amp/PC box. RoadRunner, IG3, XM, ODBC (HP Tuners), Cameras
    Pics/Videos
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by ajamils View Post
    Right here,
    And ';' go between commands and the paramaters.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Sep 2006
    Richmond, Tx: USA
    Thanks a lot for your help. Got it working
  1. RR & Iguidance problem
    By tsx004 in forum Road Runner
    Last Post: 12-05-2006, 05:57 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  3. Video problem (maybe) RR 9-5-06
    By vinzer in forum Road Runner
    Last Post: 09-09-2006, 02:29 AM
  4. Replies: 17
    Last Post: 09-04-2006, 01:33 PM
  5. GPS not found problem
    By ThEScReW in forum GPS
    Last Post: 12-20-2004, 06:39 PM
