Results 21 to 30 of 36
Thread: How to communicate with RR via COM/ActiveX?
  1. #21
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you should receive the "ONSONGSTART" in the plugin extension. Other than that, you'd have to poll it (which is pretty much what RR does with winamp). RR does everything on a 1sec basis, keeps overhead low. 2 times per second should not be too bad either though some things will only update every second, which defeats the purpose.
    Ride Runner RR's Myspace
  2. #22
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Iceman_jkh View Post
    Is there any way to know when the track changes in RR so that the app can update the current trackname as well? Does RR trigger any sort of event, or must this be done via polling?
    I'm looking at grabbing Trackname, GPS Latitude/Logitude/heading and a few things like that. In this case, I'll likely be polling 1-2 times a second. Is this bad programming practise and with too much overhead? Is there a smarter way to do it?
    You won't gain anything as far as any of the GPS data goes if you poll it 1/sec or 60/sec, as I woud assume that you know that the GPS data only gets updated 1/sec..anymore is just wasted CPU usage...
    Edit: beaten to the punch...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #23
    Nov 2005
    opps ... forgot about the GPS being that slow .
    Thanks for the info, I'll poll the data in that case.
  4. #24
    Nov 2005
    Is ONSONGSTART usable in VB6? If so, how do I get it to trigger other commands?
  5. #25
    Nov 2005
    What would be the best way to determine if RR is in FMRadio mode?
    I plan to poll for FM Mode, and only extend the power antenna when FM is on.
    Ive looked at Skin commands.txt, but there was nothing definitive. The closest I found was to try and find when the FMRadio line was MUTED and assume that when radio is muted then FM is off.
  6. #26
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I would create a varible and when you go into radio mode then just change the var between 0-off and 1-on then you would just have to poll the var to see what is current value is.
    button code to go something like this when you go into or start the radio, for the ex I'll use 'radio_status'
    Add a var to rr.ini-----radio_status=0 <--when you start rr it will assign the var to 0 and radio would be off
    then in your exectbl.ini
    "Radio","setvar;radio_status;1||Radio"
    "Audio","setvar;radio_status;0||Audio"
    Then just do the same for the other ways that you listen to music
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #27
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you can monitor all commands executed in RR via the processcommand sub.. if "RADIO" goes by, you know you went into radio mode, if "AUDIO" goes by you know you went back and so on.. you can also monitor the current screen as it is passed along with the command being executed (frm.tag).
  8. #28
    Nov 2006
    RoadRunner COM examples in C++
    Anyone have an example of communicating with RR from C++ using the COM option?
    A simple example of creating the object and doing a GetInfo would be fine.
    I must use C++ to get access to some functionality that I can't get to with AutoIt.
    Any and all help appreciated.
    Regards,
    Jim
  9. #29
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Out of curiousotisy(sp), what can't you get w/ autoit?
    I've attached the C++ examples from the RR source zip.
    Attached Files Attached Files
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #30
    Nov 2006
    Blue ZX3,
    Thanks for the zip file but that uses the Windows SendMessage method.
    What I am looking for is an example of the COM/Activex technique in C++ that is the equivalent of the VB "Set SDK = CreateObject("RoadRunner.SDK")" or the AutoIt "$SDK=ObjCreate("RoadRunner.SDK").
    I must be having a senior moment but for the life of me I can't remember how to do that same thing in C++.
    As to your question about why I need to use C++, I am playing with the Command and Control support of SAPI (voice reco) and several of the calls require wide characters (as in the L"commands.xml" form of a literal) and I can't find a way to either not have to use that form or a way to create such a literal in AutoIt. BTW, I should note that AutoIt and SAPI seem to have some "togetherness issues" (lagging, hanging, crashing) that I don't have with C++.
    My program runs fine in C++ but I need to get data from RR and send RR commands and don't really want to write the windows message processing support for message coming to my program in C++ if I can use the COM/Activex support.
    So, being an equal opportunity person relative to programming languages, I would use either C++ or AutoIt although I would prefer C++ for this one.
    Regards,
    Jim
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 08:54 AM
  2. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  3. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
