Results 1 to 10 of 12
Thread: VB6 vs VB 2005 Express
    Jun 2005
    Albuquerque
    I am trying to make a few changes in the weather plugin in order that it works behind a proxy.
    I went to the microsoft website and they don't offer Visual Basic 6 anymore. The only product I saw was VB 2005 Express. This IDE is free. I'm not sure VB6 is/was. Well, I tried to open up the Road Runner project but it's saying that it needs to migrate the project to a .NET style. It starts to migrate but ends up stopping cause it says it can't find certain .dll's (which I found were actually in the RR source directory).
    So my question is: Will RR be migrated to the new VB OR is there a way I can obtain VB6 so I can work on it?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Pretty sure you'd have to buy a copy of it (even if 2nd hand). I work with it, so always had access to it. .NET however is just way below my standards of performance and minimal requirements, so I have no plans of going into it. However, you can still make plugins for RR in .NET (or any other language). But if you want to alter the current sources/plugins I'm afraid you'd have to get VB6.
    Should be possible to import it, but I'm sure you'll have a hell of a time converting API code and such that isn't accepted in the same manner in .NET
    Ride Runner RR's Myspace
    Jun 2005
    Albuquerque
    Well thanks for the quick reply. I was afraid of that response, though.
    I will try to use the weather code and build a plugin in .NET that I can use with the default RR.
    Thanks!
    Jun 2005
    Albuquerque
    Guino,
    Do you have to "regsvr32 pluginname.dll" for every plug-in?
    Is there a way to un-regsvr if we dont' use the plugin anymore?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you have to register it cause that's how COM objects work.
    you CAN unregister using the same command with a /U as the parameter.
    Dec 2008
    How to use the DLL developed by VB .NET? Error showed when using regsvr32.
    "Dllname was loaded, but the DllRegisterServer entry point was not found. "
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    As far as i know about .net, you can't use the "regsvr32" on the dll's. Instead you'll need to use "regasm /codebase /tlb <filename>.dll". If you installed any of the .net plugins (HDRadio,SiriusRadio,XMRadio) look in their plugin folders and you'll see a "regasm.exe" and a "RunMefirst.cmd". If you open/edit the runmefirst.cmd file you will see how to use it. I've also included one from the installer here for your added convenience(aka spoon feeding).
    Attached Files Attached Files
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Dec 2008
    Add the line at end of the menu.skin
    X,SiriusComm
    But the debug log showed:
    Error loading plugin: SiriusComm (ActiveX 部件不能创建对象)
    部件不能创建对象 = Can not create object
    Dec 2008
    Quote Originally Posted by efun View Post
    X,SiriusComm
    Fixed. Need change ComVisible from False to True
    <Assembly: ComVisible(True)>
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That SiriusComm was not an extension plugin it's just an example of DLL with a COM object used in VB6... so it won't work with X,...
    There's a sample extension plugin available in C# ... it would probably help to look at it (attached), but it's good to hear you got it going..
  1. developing in VB
    By ShinkunoNamida in forum Software & Software Development
    Last Post: 07-27-2008, 11:13 AM
  2. Making Front End program in VB
    By madkad in forum Coders Corner
    Last Post: 03-02-2006, 03:02 AM
  3. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 01:51 AM
  4. SDK - VB6 App
    By Gobby in forum RR Bug Tracker
    Last Post: 05-08-2005, 05:58 AM
  5. advice for starting out in VB programming
    By Vchat20 in forum Software & Software Development
    Last Post: 02-06-2005, 02:00 PM
