1-Make sure the DPI setting of the display properties is set to normal
2-Make sure you have the fonts propperly installed -- you can NOT extract the fonts directly into the windows\fonts folder -- you MUST extract them somewhere else first then COPY them in there so they're propperly installed.
Those are the two only things that could cause the fonts to not look right.
LinkBack URL
About LinkBacks
