1 Attachment(s)
Make a switch button
I'm trying to customize the simplistique gps skins to free up more screen space for iguidance. What I am trying to do is remove the top bar of information and buttons in the red box then move them down to the yellow box. I want to accomplish this by making a switch button shown in red on the bottom right. This button would work similarily to the switch button in Chuck's skin but I could not find the code in his skin and I did not really understand the instructions in the one thread I found. In the skin commands.txt file I saw the "SWITCHBUTTON" command but im not sure if that is the command I need and what other code will allow me to switch button presets from gps controls to audio controls and vice versa.
switchbutton is normally used to switch a single button function between different options.
ie
b01,x,y,h,w,"dothisonfirtspress||SWITCHBUTTON;1>>d othisonsecondpress||SWITCHBUTTON;1>>dothisonthirdp ress||SWITCHBUTTON;1>>",""
edit
maybe have a look at these commands
"SETBUTTON" - This allows you to replace the command on any button. The Button number follows the same fashion
of switchlabel (actual button line number). The parameters are the button number and the new code.
Example: "SETBUTTON;3;PLAY"
(to set the button code of the third Bxx,xxx line of the skin to "PLAY")
"SETBUTTONID" - This allows you to replace the command on any button, but using the button ID to specify the button.
Example: "SETBUTTONID;B02;PLAY" (to set the button code defined by B02,xxx,... to "PLAY")
Whatever you do it will be complicated.
Probably the easiest way would be to have two screens and just switch between the two.
I was debating that option, but I didnt want the whole screen to have to close and reopen. I just sorta wanted the buttons to change so that I wouldn't have to reload the screen. I wanted to have a smoother transition but after looking through Chuck's code I only have a little idea of how his works. I've done some programming before but its been awhile and its not clicking in right now.
The transition should be pretty quick and smooth once you've done it the first time. When you load it the whole thing loads into memory so it's virtually instant after that.
The way I have done the various FreeDrive menus in iDrive is different screens, and yes the first swicth is RR's usual slow but once done it does swicth quicker the second time.
Maybe LS can enlighten us
I have been playing around with this, and I think it is quicker. here is an example.
/, This section defines the commands for the top Menu Bar
/, For the Audio / Visual Menu's etc see sections below
/, This line defines MenuSwap Command, and sets the variable to swap between 3 values.
/, 2 line option, and remove the comments from the 3 line option. Then add coomands
/, to the cM2B2 etc lines below
/, "MNUSwap",“BYVAR;MenuSwap;MNU1<<MNU2<<MNU0||BYVAR; MenuSwap;SETVAR;MenuSwap;1<<SETVAR;MenuSwap;2<<SET VAR;MenuSwap;0” This line for third Menu
/, This line defines MenuSwap Command, and sets the variable to swap between 2 values.
"MNUSwap",“BYVAR;MenuSwap;MNU1<<MNU0||BYVAR;MenuSw ap;SETVAR;MenuSwap;1<<SETVAR;MenuSwap;0”
/, This section calls the button image comands for each Menu Line
"MNU0","ImageMenu1||MNUBTN1"
"MNU1","ImageMenu2||MNUBTN2"
/, This section loads the button images in the right places, and sizes
"ImageMenu1","LOADIMG;1;0;800;60;Menu1.gif;Out||LO ADIMG;1;0;800;60;Menu1.gif;Off||LOADIMG;1;0;800;60 ;Menu1-d.gif;Down||LOADIMG;1;0;800;60;Menu1.gif;On"
"ImageMenu2","LOADIMG;1;0;800;60;Menu2.gif;Out||LO ADIMG;1;0;800;60;Menu2.gif;Off||LOADIMG;1;0;800;60 ;Menu2-d.gif;Down||LOADIMG;1;0;800;60;Menu2.gif;On"
/, This section sets the button and label commands
"MNUBTN1","SWITCHLABEL;3||SWITCHLABEL;4||SWITCHLAB EL;5||SETBUTTON;2;cM1B2||SETBUTTON;2;cM1B2||SETBUT TON;3;cM1B3||SETBUTTON;4;cM1B4||SETBUTTON;5;cM1B5| |SETBUTTON;6;cM1B6||SETBUTTON;7;cM1B7||SETBUTTON;8 ;MNUSwap"
"MNUBTN2","SWITCHLABEL;3||SWITCHLABEL;4||SWITCHLAB EL;5||SETBUTTON;2;cM2B2||SETBUTTON;3;cM2B3||SETBUT TON;4;cM2B4||SETBUTTON;5;cM2B5||SETBUTTON;6;cM2B6| |SETBUTTON;7;cM2B7||SETBUTTON;8;MNUSwap"
/, This section defines the button commands, to keep the above section readable.
"cM1B2","PREVTRACK"
"cM1B3","PLAY"
"cM1B4","NEXTTRACK"
"cM1B5","VOL-"
"cM1B6","MUTE"
"cM1B7","VOL+"
"cM1B8","MNUSwap"
"cM2B2","AUDIOMENU"
"cM2B3","VISUALMENU"
"cM2B4","LOAD;www.Skin"
"cM2B5","APPSMENU"
"cM2B6","LOAD;Weather.Skin"
"cM2B7","LOAD;External_GPS.skin;!QWidget;C:\Progra m Files\Navigator4_4\Navigator.exe;Navigator - ["
"cM2B8","MNUSwap"
/, This section defines the commands for the Audio Menu Bar
/, This section Loads the button images and commands for the Audio Menu
"AUDIOMENU","AudioImages||AUDIOBTN0"
"AudioImages","LOADIMG;1;0;800;60;Audio.gif;Out||L OADIMG;1;0;800;60;Audio.gif;Off||LOADIMG;1;0;800;6 0;Audio-d.gif;Down||LOADIMG;1;0;800;60;Audio.gif;On"
"AUDIOBTN0","SETBUTTON;2;cA1B2||SETBUTTON;3;cA1B3| |SETBUTTON;4;cA1B4||SETBUTTON;5;cA1B5||SETBUTTON;6 ;cA1B6||SETBUTTON;7;cA1B7||SETBUTTON;8;cA1B8"
"cA1B2","SETVAR;MenuSwap;0||LOAD;Audio_Player.skin "
"cA1B3","SETVAR;MenuSwap;0||LOAD;Audio_Browser.ski n"
"cA1B4","SETVAR;MenuSwap;0||LOAD;Radio.Skin"
"cA1B5","SETVAR;MenuSwap;0||LOAD;XM.skin"
"cA1B6","SETVAR;MenuSwap;0||LOAD;Sirius.skin"
"cA1B7","SETVAR;MenuSwap;0||LOAD;Mixer.skin"
"cA1B8","SETVAR;MenuSwap;0||LOAD;Menu.skin||MNUSwa p"
/, This section defines the commands for the Video Menu Bar
/, This section Loads the button images and commands for the Video Menu
"VISUALMENU","VisualImages||VISUALBTN0"
"VisualImages","LOADIMG;1;0;800;60;Visual.gif;Out| |LOADIMG;1;0;800;60;Visual.gif;Off||LOADIMG;1;0;80 0;60;Visual-d.gif;Down||LOADIMG;1;0;800;60;Visual.gif;On"
"VISUALBTN0","SETBUTTON;2;cV1B2||SETBUTTON;3;cV1B3 ||SETBUTTON;4;cV1B4||SETBUTTON;5;cV1B5||SETBUTTON; 6;cV1B6||SETBUTTON;7;cV1B7||SETBUTTON;8;cV1B8"
"cV1B2","SETVAR;MenuSwap;0||LOAD;TV.skin"
"cV1B3","SETVAR;MenuSwap;0||LOAD:DVD.skin"
"cV1B4","SETVAR;MenuSwap;0||LOAD;Video.Skin"
"cV1B5","SETVAR;MenuSwap;0||LOAD;PICS.skin"
"cV1B6","SETVAR;MenuSwap;0||LOAD;www.skin"
"cV1B7","VISU"
"cV1B8","SETVAR;MenuSwap;0||LOAD;Menu.skin||MNUSwa p"
You really need to print this out and work through it, but it works ok. You will still need to load files, and as jnorion says, the pain is only the first time (where have I heard that before lol).
Cheers
KPJUK
Awesome, thanks for the post. Now I have to see if I can make this work in my skin.
