Results 1 to 10 of 15
Thread: Hibernation and Startup Questions
    Sep 2006
    Richmond, Tx: USA
    I have following two urgent questions (since I'm on a road trip)
    1) Everything was working perfectly till yesterday when I installed Enginius USB Wifi card. Now what happens is the software for it keeps the computer from hibernating. Everytime RR tries to hibernate, it gives a pop-up and stops it from hibernating. How can I close the software (since I'm using RR as shell I don't see the task bar where its at) before hibernation and open up again when RR starts ?
    2) I'm using "startcommand" for running Xport on starup but now I want run Philips Soundcard software on startup too. I tried using "startcommand" but it seems like RR does not like two startcommands. How can I run more than one command at startup ???
    Prompt reply will be appreciated.
    Mar 2006
    Colorado, but Canadian!
    well for #1, go to system properties, harware device manager. locate your usb section under hubs or root, and then uncheck the box that says something like "dont let computer sleep while this device is active" or something. im in airport now on phone, so i dont know exactly, but pretty sure it is like that.
    1.9in x 2.9in -- 47mm x 73mm
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1) you can try running devcon.exe to disable the card before hibernating, then running it again to re-enable it after resuming. You'll have to lookup the syntax and card information then just place the commands in exectbl (ONSUSPEND/ONRESUME events). Making .bat files is a good way to test/set-up.
    2) use || to separate commands (i.e. AUDIO||STOP)
    Ride Runner RR's Myspace
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by guino View Post
    1) what type of information do I need to use devcon ?
    2) so it should be something like
    startcommand=c:\xport.exe||c:\soundcard.exe
    Nov 2006
    go into rr config and find the box thats says force hibernation- even if hardware port it preventing, that should work i think
    PC
    AMD 3500+ 2.2Ghz, MSI K9VGM-V Motherboard,
    Geil 512MB PC4200 DDR2-RAM, 7" Lilliput Touchscreen, 30GB HD
    Audio
    300 watt RMS 2 Channel MTX AMP, 500 watt RMS D-Class MTX AMP, 2 Front - 5 1/4" Sony Xplods,
    2 Back - 6 1/2" Sony Xplods, 12" MTX Sub
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by Legacy View Post
    That is already checked but that is not working.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Type 'devcon help' in the command prompt for details. You'll need the device path along with the disable/enable commands from devcon -- you may have to google it, it's not hard but it's highly dependent on your hardware so there's nothing I can do to tell you what to type in. It's basically: 'devcon disable <device>' and 'devcon enable <device>' but the device you'll have to find with 'devcon find *'
    startcommand is for RR commands (as in skin commands.txt), if you want to run applications you should use: "RUN;C:\xport.exe||RUN;c:\soundcard.exe"
    Sep 2006
    Richmond, Tx: USA
    aren't skin commads for skin only ? I've been sucessfully using startcommand for xport. Now all I want do is run another command with it. Is it not possible to do multiple commands using startcommand ?
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Hi Ajamils,
    You can define a command in ExecTbl.ini like
    "DoThis","RUN;c:\Roadrunner\Xport\Xport.exe||RUN;c :\somethingelse.exe"
    Then set startcommand to
    startcommand=DoThis
    cheers
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Sep 2006
    Richmond, Tx: USA
    Quote Originally Posted by kpjuk View Post
    Hi Ajamils,
    startcommand=DoThis
    cheers
    KPJUK
    Thank you, will try it out.
  1. hibernation freezes upon startup
    By NYCdesignkid in forum Software & Software Development
    Last Post: 02-28-2009, 08:43 PM
  2. CF & Hibernation Issue
    By mmk999 in forum CF Bug Reports
    Last Post: 04-27-2006, 12:16 PM
  3. ME not loading from Hibernation
    By TheMayor in forum Media Engine
    Last Post: 11-22-2005, 10:00 AM
  4. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 05:41 PM
  5. computer freezes at hibernation startup
    By bobthebaker in forum General Hardware Discussion
    Last Post: 01-12-2005, 08:38 PM
