Results 1 to 4 of 4
Thread: Resetting Problems
    Feb 2006
    Resetting Problems
    Hi Everyone,
    I just installed Tinyxp.. When hitting the SRRESET (sirius reset) button, nothing happens using mitch's sirius alpine adaptor.. When using regular xp, it works fine. Any ideas on what is missing and how to fix it?
    Thanks for any help.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Does the sirius function work normally when starting RR ? cause that function does not require any extra files or anything, I mean, if it works using RR from normal start it should work any other time. Unless you've got the wrong port or you've got it on some "iffy" usb-serial adapter. To me it's probably the wrong port setting or something.
    Ride Runner RR's Myspace
    Feb 2006
    works fine
    Yeah, works fine when i start up... Just if I hiber. then wake and try to reset.
    Other thing I get on my xp full install is freezing on loading serial devices @ startup. Don't think it's related tho?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    how are you pluggin mitch's board into the computer ? if you're using a USB-Serial adapter, I'd suggest trying a few others -- I used to have one that would freezup too, the one I currently use works fine (never needed to be reset either). The cheap ones tend to have crappy drivers.
  1. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 06:17 PM
  2. Car voltage problems
    By cheerio in forum General MP3Car Discussion
    Last Post: 08-16-2004, 09:01 AM
  3. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
  4. Setup nearing completion, having all kinds of problems (yeah i did a :search:)
    By therussman2002 in forum General Hardware Discussion
    Last Post: 06-21-2004, 07:09 PM
  5. Shutdown Problems - Troubleshooting Guide
    By brettwmd in forum Power Supplies
    Last Post: 05-28-2004, 12:46 PM
