Results 1 to 4 of 4
Thread: iGNative kills my route :(
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I've been having this problem for a few weeks and have finally found the culprit. If i have ignative set to true in rr.ini and create a route it starts as it should. But when i go to a different screen then return to my gps screen the route is gone. iG remains open.. stays one instance but the route is cleared. If i change ignative to false this doesnt happen but iguidance only embeds correctly have the time (and strangely still without the menus or borders). What gives?
    Live mp3Car Facebook Chat
    Raw Wave lostreception's Avatar
    NY
    do you continue to hear guided sounds with the route its possible there is a multiple instance of IG running and it reemebeds itself over the original one with the route. alos check to see if the gps info is still updating after the "glitch"
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Woodbridge, VA
    Blog Entries
    55
    no the guided sounds go away. sometimes i will hear them clip halfway thru the instruction. i also check task manager for multiple instances. and the gps stays connected cause when i return to the gps screen i still see me moving just no route.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The only different between setting ignative=true and false is when true, iG window became a child window of RR and it is treat like another part of RR. When set to false, RR "steal" iG and embedded like any other apps.
    Border, menu bar trim is the same regardless of true or false.
    It's just weird that I have no problem at all.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. my iG3 keeps clearing the route
    By Sonicxtacy02 in forum GPS
    Last Post: 11-17-2006, 09:59 AM
  2. route 66 2001-2002
    By macinavan in forum MacCar
    Last Post: 09-27-2006, 02:20 PM
  3. Replies: 0
    Last Post: 07-07-2006, 05:11 PM
  4. FD 0.82 update
    By CdRsKuLL in forum FreeDrive
    Last Post: 07-27-2005, 07:34 AM
  5. Anyone used route 66 2004 in UK?
    By tekta in forum GPS
    Last Post: 03-23-2004, 08:09 AM
