Having you been messing with drive letters and such ? Did you re-install the same winamp version ? Did you install winamp LITE by any chance ? Those are my best guesses of possible causes.
hi, not sure where this should go because I am quite ****ed off at the moment, I get in my car, and winamp won't work, says that the direct sound driver isn't working or something, after not being able to get it to work, i just uninstalled and reinstalled winamp... it works now.
However, the problem is, before (i'm using the alpine skin btw) when i went to list to add music i could click on an artist and click select, and it would add all the music from that one artist to my playlist, now it adds the physical folders, and dosn't play at all, you can only play one albulm at a time. Does anyone konw how to fix this?
Ride Runner RR's Myspace
I didn't reinstall lite, same drive and directory, winamp version i'm not sure of, guess I'll try to downgrade to a slightly older version, see if that helps. Thanks for the quick reply
ok, I'm an idiot, winamp 5.24 works fine, but 5.32 does not, thanks again
