Results 1 to 3 of 3
Thread: Removing right/left click lilliput tool on video playing.
    Dec 2006
    Belgium, Lokeren
    Is there a way to let dissapear the Lilliput tool to select the right mouse buttom when playing a video ?
    I have it even in the main screen of RR. Can it be removed there also ?
    Didn't found an answer via the search (or I used a bad keyword)
    Thanks.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    well if RR is running there is no reason to even have that tool running also, since you cant right click anything in RR. Just turn it off and have it off by default, if you need it when you go to your desktop, just create a shortcut to it somewhere and run it. Thats the simple version.
    If you are good or know how to script (insert language here) then you should be able to write a script that would turn it on off at the appropriate times. You should also be able to do this in RR, for example when you minimize or exit RR you can have it also run the tool right before.
    I cant remember right now (since i dont ever use that tool on my lilly) but i think there are options for it to always be either on top or under all windows, may just be as simple as setting that option.
    beer replenishment fund
    mp3car live search
    Dec 2006
    Belgium, Lokeren
    Quote Originally Posted by liquid_smoke View Post
    Thats true. I will add it to my applications so I can start it from there.
    Not so good, so will forget this solution.
    Will take a look if I can find something.
    Anyway, thanks for the sugestions !!
    KR.
  1. How do you save Lilliput video settings?
    By ML430 in forum Input Devices
    Last Post: 06-10-2004, 12:37 AM
  2. Playing Video
    By FunkDaMonkMan in forum FrodoPlayer
    Last Post: 05-09-2004, 06:43 AM
  3. ME playing NSV video format?
    By mobileh1 in forum Media Engine
    Last Post: 05-01-2004, 10:02 PM
  4. I need a video player that crops out the black bars while playing.
    By cproaudio in forum Software & Software Development
    Last Post: 07-27-2003, 06:41 AM
  5. Playing different types of music and video files
    By wysiwyg in forum General Hardware Discussion
    Last Post: 02-10-2003, 11:26 AM
