Results 1 to 2 of 2
Thread: RRunner/iGuidance cant find COM port?
    Jul 2006
    I have installed both iGuidance and Microsoft Mappoint. I setup the configuration to prompt a menu when selecting GPS. I set iGuidance up in the "external" field, and entered the COM port.
    Mappoint works fine. But iGuidance seems experience 2 issues. 1.) detecting the gps and 2.) "skinning"? the application. Below are details:
    1.)When I click EXTERNAL from the GPS menu, the software can not find the gps. It does not help if I click on tools-->gps-->com port. I have to quit roadrunner COMPLETELY in order for iGuidance to operate, then I can launch Roadrunner (iGuidance will be in the background). If I then open iGuidance from within RoadRunner, a new instance of iGuidance will open, but will have the said GPS error.
    2.) When launching iGuidance, a small window appears, almost too small to be functional. I can however resize this manually. I like the way RoadRunner opens MapPoint, and I'm wondering if it can open iGuidance in the same manner?
    Thanks for anyone's help with this!
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    In oder for you to run Road Runner and iGuidance you need a com port splitterlike XPort3. Mappoint is native in road runner and needs only one com port. when you run iGuidace and road runner you need 2 com ports for it to work.
  1. NMEA extraction AppleScript need help
    By zapwizard in forum MacCar
    Last Post: 05-05-2006, 02:10 AM
  2. bu-353, sirf/nema, port settings
    By kbyrd in forum GPS
    Last Post: 12-02-2005, 05:43 PM
  3. Port Com in RR!BUG??
    By sevensad in forum Road Runner
    Last Post: 11-29-2005, 04:45 PM
  4. Replies: 4
    Last Post: 07-04-2005, 05:38 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
