Page 14 of 48 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 475
Like Tree1Likes
Thread: FreeFone 1.3 Full integration with Roadrunner
  1. #131
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Konrad View Post
    Yes, please, that would be nice .
    @JohnWPB
    I'm also interested in your transparent gauges. Is the exe included in your skin (didn't check now, I'm short of time, but I guess you uploaded your skin, right ?) ?
    Yes, they are in included with my skin, link is in my sig. As mentioned above, they are not exe's, but are just simple swf flash files. This means they can be resized to any are of a skin that you would want to put them in. They are vector based, meaning no matter how large you make them, they will still be perfectly clear.
    My Fiero Build Thread
  2. #132
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by Zeeshan0581 View Post
    how would u go about if your phone doesnt support serial port service through BT. I have a Motorolla E815 and doesnt seem to have serial port service, atleast i dont see it under services. Anyway to use DUN port??
    Hi, yes just use the DUN port, My N95 doesnt support the seral over bluetooth but if you just put in your DUN com port then this works great :-)
    CdR..
    Attached is the FreeFone PSD.. I've messed with it abit so it might be a bit of a mess and I cant be arsed cleaning it up, but its attached for u :-)
    Attached Files Attached Files
  3. #133
    May 2007
    two phones?
    Hi CdRsKuLL, great skin great programs.
    Everything is ok but i have two phones and i wonder if your ultimate skin can work with two devices in the same time. One listening on com32 and one on com 30. Who have first the connection to pop up. I tried with the standalone version, i opened two session of freefone and they connect to the phone set in the com specified in settings file. I can call and i can be called. Is there a way to integrate that in your skin?
    Thnx
  4. #134
    Aug 2004
    Germany
    Thanks alot guys .
  5. #135
    Variable Bitrate Pistolen08's Avatar
    May 2005
    Tampabay, Florida
    Has anyone gotten freefone to work with any of the blackberries? I'm looking at buying one and compatibility with my carpc is very important. Thanks.
  6. #136
    Feb 2004
    Manchester
    Just a little update.. I have spent alittle bit of time on freefone, its now able to load a background image under its buttons.. with a bit of messing you can position this background so it looks like its part of your skin.
    I have also added better compatablility for ff for the Nokia N series range, it now tells you whos calling (gets the called ID) and also shows this onscreen. You still have to use the external phonebook.txt for it as theres no way of fetching the phones internal one.. but it now searchs through the external phonebook for a matching name to the number thats calling.. :-)
    Just got to give it a test and add few more things then I will release Freefone 1.5
    cheers
    CdR
  7. #137
    Sep 2005
    AT commands
    I was trying to figure out how i would find AT commands for the pickup and hangup buttons on a treo 650. Does anyone know how i could find this out
  8. #138
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Thats looking great CDR! Can't wait to give it a go
  9. #139
    Oct 2006
    CT
    Well i used the DUN serial port and FF finds the phone, connects to it, but It cant load my phone book, missed calls, dialed calls, ..etc, nothing.
    It doesnt show me incoming call screen if the phone is ringing..
    I try to dial, and it puts the phone in 14.4k mode??
    Any thoughts??
    Also, I used the same phone in an infinity that had BT integrated into it, bonded the phone, and used it to answer calls and dial using the phone book, and sound was routed to the car speakers and mic?? any idea how that was done?
  10. #140
    Low Bitrate crispyrabbi's Avatar
    Nov 2006
    Sweden
    Tried it out with sonyericsson K810I and its working allright. One problem is that I have to connect the bluetooth audiogate manually. Maybe it just need some adjustments in the freefone settings.ini or maybe in the phone itself. Anyone else experienced this problem with sonyericsson?
    AOPEN MINIPC 945 VXR, CORE DUO T2400, 512MB, 120GB, Wlan, CARNETIX CNX-P1900, 1020TSV TFT 10.2" Touchscreen, BU-353 GPS, wlan-antenna, X3 integration to HU, D-link DUB-H7 USB 2.0 Hub, Wireless RF-keyboard, Logitech USB noicecancelling mic, NV RVcam
  1. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 07:06 AM
  2. Can roadrunner be full screen?
    By black06stang in forum Road Runner
    Last Post: 05-09-2006, 10:06 AM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  4. Replies: 4
    Last Post: 02-18-2005, 01:11 AM
