Page 15 of 48 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 475
Like Tree1Likes
Thread: FreeFone 1.3 Full integration with Roadrunner
  1. #141
    Feb 2007
    Richmond Virginia
    I still have been unable to download. anything I need to do? I registered at Freedrive but can not post of download but I can change my profile.
  2. #142
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    just a question, is there a way to change the font color the one's that show's the dialed number and the big letter that flashes on top of the contacts list?(the white font's)i did some skinning to my crappy skin, and i dont like the way it look's, because i cant change the color in those fonts.
  3. #143
    Mar 2007
    Quote Originally Posted by CdRsKuLL View Post
    Just a little update.. I have spent alittle bit of time on freefone, its now able to load a background image under its buttons.. with a bit of messing you can position this background so it looks like its part of your skin.
    I have also added better compatablility for ff for the Nokia N series range, it now tells you whos calling (gets the called ID) and also shows this onscreen. You still have to use the external phonebook.txt for it as theres no way of fetching the phones internal one.. but it now searchs through the external phonebook for a matching name to the number thats calling.. :-)
    Just got to give it a test and add few more things then I will release Freefone 1.5
    cheers
    CdR
    I've not got round to sorting the phone out in mine. I look forward to the new release, I must check if my sign up worked on the Download site as I couldn't DL before for some reason. I don't recall an activation email either ATM, tho it was a couple of weeks ago I last tried.
    \v/
  4. #144
    Jul 2004
    Quote Originally Posted by Pistolen08 View Post
    Has anyone gotten freefone to work with any of the blackberries? I'm looking at buying one and compatibility with my carpc is very important. Thanks.
    I'm looking for the samething. Have a 8800 and so far nothing has worked.
    2003 Black Impala
  5. #145
    EL CAMINO's Avatar
    Jul 2005
    i have never been able to download, i'm using the version included in freedom alpha, hope is ok with you CDR.
  6. #146
    Variable Bitrate Pistolen08's Avatar
    May 2005
    Tampabay, Florida
    Quote Originally Posted by Dwaine View Post
    damn, that really sucks. I was looking at the pearl/curve, but carpc compatability is a requirement for me. When you say nothing worked, do you mean that it wont connect to freefone? If it is conecting to freefone, but just not able to receive/make calls, it might need different AT command. You can change these in the settings ini file. Are you sure it is paired correctly with the computer? Thanks.
  7. #147
    Oct 2006
    CT
    does FF work with LG VX8300 with verizon?
  8. #148
    Newbie EL_GRECO101's Avatar
    Mar 2007
    Keratsini - Greece
    Quote Originally Posted by YellowMater View Post
    Unfortunately Iíve the same problem...
    Please someone to advice!
    Regards.
    Virtuousness & Daring...!
  9. #149
  10. #150
    Mar 2007
    No one seems to be listening to my plees on the Freedrive site I.. Just... wanna... log on... and... DL... Phonecontrol...
  1. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 07:06 AM
  2. Can roadrunner be full screen?
    By black06stang in forum Road Runner
    Last Post: 05-09-2006, 10:06 AM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  4. Replies: 4
    Last Post: 02-18-2005, 01:11 AM
