Page 39 of 48 FirstFirst ... 2930313233343536373839404142434445464748 LastLast
Results 381 to 390 of 475
Like Tree1Likes
Thread: FreeFone 1.3 Full integration with Roadrunner
  1. #381
    May 2006
    Calgary, Alberta
    Quote Originally Posted by maxthebuilder View Post
    In my case it's Bluesoleil drivers causing the problem, not adapter...
    In Windows? I think I still have the driver CD for mine, I can send you the .iso if you like. That one worked for me under Windows XP, I was able to pair a few things with it after figuring out the interface. But once I moved to Vista or Linux, it never worked after. The updated drivers are available on the BlueSoleil website but you have to buy them.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  2. #382
    Mar 2008
    My BS install is fine me thinks... I can play music from my mobile to the desktop, retrieve the phone book, etc.
    I believe, something is not right with the BT COM ports.
    BS created 2 ports (COM4 and COM5) for the desktop PC (outgoing?) and 1 port for my phone (COM6).
    When I retrieve the phone book, the COM6 gets connected.
    When I configure FreeFone to use COM6 I can see it trying - the status of COM6 changes from Idle to Connected to Idle to Connected to Idle, etc in an infinite loop.
    What can be wrong there? Anyone? What are the right BS settings?
    Thanks!!
    Quote Originally Posted by Maheriano View Post
  3. #383
    Nov 2008
    phonemode
    I had a simulair problem with my Nokia 6310i.
    It keeps connection and disconnecting.
    Since i changed the Phonemode from 2 to 3 in the settings ini it works great.
    I get the phonelist, i can make calls etc etc.
    Some probs though.
    I cannot seem to get the audio to work. Think it might be the BT dongel im using.
    And if i call somebody and that person answers the call, freephone dissapears and only comes back if the phonecall is ended.
    Besides that ive been trying to get freephone to intergrate with FX40 skin but no succes. Once freephone is started i cannot return to RR.
    Suggestions?
  4. #384
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    I'm new to bluetooth, so be nice.
    I'm trying to get Freefone to work with my LG Chocolate 3 (LG VX8560)and it just doesnt want to be stabile. I can get it connected and send a call out, but it wont recieve a call. I've tried it with the BS drivers that came with it (New and old versions) and also with windows BT drivers. No luck. Also, I have to have the bluetooth discover the phone again (which takes several attempts) after I restart the computer. any help?
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  5. #385
    Mar 2008
    Can anyone please confirm if Freefone works with Bluesoleil at all?
    And if it works - how to configure it right?
    Thanks!
    Also, is there a real alternative to Freefone to use with RoadRunner (which would be compatible with BS)?
    Thanks!
    --max
    Thanks!!
  6. #386
    Mar 2006
    Pennsylvania
    Thanks!
    Thanks!
    --max
    Ditto.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  7. #387
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    I have been trying to download freefone for three days and the site is down. Is there another site other then CdRsKuLL's homepage to get this from?
  8. #388
    Dec 2008
    Quote Originally Posted by rizaydog View Post
    I have the same issue, any ETA for the site to be back up?
  9. #389
    Feb 2008
    scotland
    me to
  10. #390
  1. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 07:06 AM
  2. Can roadrunner be full screen?
    By black06stang in forum Road Runner
    Last Post: 05-09-2006, 10:06 AM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  4. Replies: 4
    Last Post: 02-18-2005, 01:11 AM
