Sorry if I missed an entry about it, but it is possible to design/use a skin with freephone that doesn't need to run flash ?
Sincerely,
Jurgen
anyone get this working with v3 razr? i can dial and hang up, but no sound... go figure. for such a popular phone, it sure as hell is hard to use with anything cool.
Car Pc progress meter:
[-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
Sincerely,
Jurgen
redls1bird - Are you talking about sound between the Phone via Bluetooth to the PC, ie Audio Gateway ?
If you are then i'm affraid the Razr will let you down on this score. The Razrs only have one bluetooth channel, so at the moment you are using it for the data connection to view the phones contents & dialling etc.
This is not a failing of CdRsKuLLs software i can assure you.
To use Audio gateway to its full potential you will have to source a phone which has multiple connections. I believe some of the more recent Sony Ericsons have this ability.
Steve
(also a V3i owner!!)
System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
At the moment no, but I will be releasing a skinnable version soon. All that will be flash will be the contact list, everything else will be skinnable in rr, buttons, numberbox etc.. This shouldnt take to much cpu usage then.
The next release is coming along and will be out soon. This will be version1.4
CdR
will it have some of the options i referred (in post #25)? that would be great
i've made additional tests but still have the same problem: phone (nokia 6021) doesn't hangup. I also couldn't get the picture to display, when a known number calls in...
anyway, i'll try v1.4 when it comes out! thanks!
I have read many threads with regard to the Razr's inability to do more than 1 BT connection at a time. I had pretty much accepted that I would not be able to control the phone and have the audio work at the same time, as hardware issues are difficult (impossible?) to overcome.
After sitting in my father-in-law's new Lexus, however, it appears as though the problem can be solved in software. His Razr is completely controlled by the software in his vehicle. When he makes calls, the audio comes through the car's speaker and his voice is transmitted over the built-in mic. Hopefully, someone can figure out how to do this and implement it in either FreeFone or Phoco.
@tiagoc :
I haven't installed freephone yet or gotten too deeply into if because of the fact that it (still) needs flash and I don't want to put "that much stress" on my MII-12000 motherboard.
But I know from playing around with RRMobile that the 6021 (which is my phone as well) needs a different AT command than the standard ATH which is in the ini file.
I did a quick download of FreeFone 1.3 to check that and it also uses the wrong AT command, change the following line in your settings.ini file
Hangup=ATH
to
Hangup=AT+CHUP
and you should be good ...
Let me know how that works out for your ...
Sincerly,
Jurgen
CRD, will be that FLA source (for the contact list) available as well so we can theme the list as well ? great job ! Hope will work with my P910i...
I will make the font colour in the list changable and also the background image, so you will be able to make it look fully integrated, thats the idea anyway.
CdR
jpuype: thanks! i'll try that code and see how it works
edit: the AT+CHUP worked. thanks a lot!!![]()
