Page 41 of 48 FirstFirst ... 313233343536373839404142434445464748 LastLast
Results 401 to 410 of 475
Like Tree1Likes
Thread: FreeFone 1.3 Full integration with Roadrunner
  1. #401
    Constant Bitrate ramez75's Avatar
    Dec 2006
    Nazareth PA
    I still cant seem to get the FreeFone to work. It seems like I am missing something or doing something wrong. Right now my goal is to make freefone to work as standalone then go to phase 2 and use it with RR
    I have a Kensington USB bluetooth and LG VX9400 cellphone. They are both paired. I can see my computer name in my cellphone and when I open "My Bluetooth Places\Entire Bluetooth Neighborhood" on the computer and look for bluetooth device I can see my cellphone so I know they are paired. I used the transfer option in bluetooth and transfered pics back and forth. So the link is their.
    From the "Device Manager, I found that the Bluetooth comport is 4 so thats what I am using.
    Is that the way to go about or I need to do something else. Their are other optiong in the "My Bluetooth Places\Entire Bluetooth Neighborhood" other than transfer, dont know them top of my head
    Thanks in advance
  2. #402
    Newbie Huss's Avatar
    Dec 2007
    make sure the bluetooth software is not connected to the phone in any way ie my bluetooth place.
    freefone won t share, and once you run freefone it will look for the port you set in the ini file.
    hope this helps.
  3. #403
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Huss, if I would look in "my bluetooth places", and see my phone listed, do I remove the phone from the list? Or change it so it doesn't connect to the phone?
  4. #404
    Dec 2006
    Nazareth PA
    I tried both ways phone connected/paired and not paired. I even disabled the phone too and nothing happens. I click on Freefone icon in the standalone folder and all i get trying to connect.
    I know I have the comport correct because the Device Manager shows the Bluetooth is connected to it. I tried in the *.ini file mode = 2 and mode = 3. Also nothing. It seems I am missing something else
  5. #405
    Dec 2007
    you need to make sure that when you switch on the pc that it dose not connect to your phone in any way,
    you could try uninstalling your bluetooth software and just use windows driver to connent the phone, this is how i use freefone with no probs...
  6. #406
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The best thing you can do is set debug=true in settings.ini and see what (if anything) is coming as responses from the phone. As long as you have a working port to talk to your phone, chances are good it will work with most newer phones.
    Ride Runner RR's Myspace
  7. #407
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    Can it be controlled (dial numbers, answer/hangup phone) as well as have audio through one bluetooth connection?
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
  8. #408
    Nov 2008
    If i look in my BT menu and click on my phone and see properties, i can see more than one comport connected. One incoming, one outgoing and one serial port connection.
    Are you sure you have tried the right comport?
    With my nokia 6310i it works perfect, only thing is i cannot get the audio to work using Freephone. But i do see my contact list and i can receive and make phonecalls.
    My advice, check the comports that you have and test them.
  9. #409
    Oct 2005
    Arizona
    When I loaded the BT software, it set up a blue tooth comport on com 8. This was in the device manager whether the BT was connected or not. However when I connected the BT to my computer, it connected through com 9 so don't believe what the device manager says. If you want to know what com port the BT will use when you connect, go to the Bluetooth Serial Port properties window from My Bluetooth Places and there will be a drop down box with a com port number (don't know why it's drop down because it only lets me select the com port it gives me). Once I changes the freefone setup.ini settings to com 9 instead of com 8, the phone and computer communicated. I have many other problems with freefone now that it connects but that should at least get you past the connecting stage. Good luck.
  10. #410
    Dec 2006
    Nazareth PA
    Kershoek
    I looked into the phone properties through the BT Menu, all I see is General and Authorization. I dont have any thing related to comports
    Chuckbyu
    I checked the bluetooth comport the way you suggested and it also shows com4 and I cant change it from the drop menu.
    All this and still cant connect..... Outside Freefone I have total visibility between the PC and phone i can transfer pics, messages.
    Do i need to put the freefone standalone folder in a certain directory, right now its on my desktop.
    Anymore suggestions
    Could my phone not be compatible with freefone. Can someone send me the setting.ini just want to make sure I am not missing anything within the file.
    Thanks for all your help
  1. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 07:06 AM
  2. Can roadrunner be full screen?
    By black06stang in forum Road Runner
    Last Post: 05-09-2006, 10:06 AM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  4. Replies: 4
    Last Post: 02-18-2005, 01:11 AM
