Page 46 of 48 FirstFirst ... 36373839404142434445464748 LastLast
Results 451 to 460 of 475
Like Tree1Likes
Thread: FreeFone 1.3 Full integration with Roadrunner
  1. #451
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Your Serial port Profile on the phone is definitely not going to work (it's probably for applications).
    You need to connect using the DUN (Dial Up Network Profile) -- This is a SERVICE on your phone, much like Serial Port, HeadSet/Audio GateWay -- If your phone has a PAN profile/service, then it's possible you won't have the DUN/Dial-Up service and in this case there's nothing you can do to make it work. The Dial Up service/profile is to use your phone as a MODEM (to actually dial numbers and such), the PAN service/profile is to network your PC with the Phone's Network (for internet access ONLY). Many manufacturers are only providing PAN these days cause they think nobody will want to use DUN... (bastards...).
    If you get to add this service, you should see in icon on your bluetooth neighborhood for this as well, then windows should also add a Modem Under device manager for it -- which you'll be able to check/see the com port it's at, then set it.
    Ride Runner RR's Myspace
  2. #452
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Try changing the com port to a lower number, not sure if Freefone has the capability to use com ports that high
    You can change it in device manager - com ports.
  3. #453
    Dec 2007
    I think if you don't see modem dial up network under service, you are pretty much out of luck.. Look for under service to locate it besides those 3 services. You will see a list of all the services you can use for your phone. once install/enable/connect? that service, you will see modem under your device manager.. expand that and you ought know how to go from there.... I had the same problem until i enabled modem dial up network service...
  4. #454
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    Well I cant find any DUN on my phone. I'll try to lower the com number, but I think Im f'ed.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
  5. #455
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Enforcer View Post
    3. See if you can find a manlal or something online which lists the AT commands for your phone.
    Is Blue your spelling teacher?
    My Fiero Build Thread
  6. #456
  7. #457
    Jan 2006
    Anyone have this working with a nokia e71?
    I have it almost working perfect.
    It'll make and answer calls, except that It wont display caller ID.
    also everytime my cellphone looses signal, ff will pop up and think there's an incoming call. weird.
  8. #458
    Jun 2009
    Hi,
    I wonder if you can help... I have read all the posts and am ready to try anything!
    I'm using RR and Freefone that comes with the freedom 1.2 skins.
    I have win xpsp3
    Widcomm (broadcom) stack on a cadmic USB Bluetooth dongle
    With an HTC Touch Pro (Raphael) windows mobile 6.1 pro
    I’ve set up and paired an audio gateway and a DUN
    Outside of road runner, if I ring my mobile phone I get a windows popup bubble, which presents the caller id then if I hit answer it connects the audio gateway, both PC microphone and speakers work fine.
    If I dial out from my mobile (when the headset icon is showing) the PC audio gateway is used (yet!)
    Inside HyperTerminal:
    I can dial out using atd0123456; which causes the phone to wake up and dial, but once connected it does not use the audio gateway.
    I can dial into the mobile and answer using HyperTerminal on the pc via the ATA command, but again the sound is routed through the phones speakers. And not through the pc
    Inside RR/Freefone
    Freefone will connect to my phone, and can dial out, but again as with HyperTerminal, the audio headset is not figured.
    Extra frustratingly Freefone will not 'see' an incoming call. and RR effectively hides the popup bubble of the Bluetooth handsfree jobby.
    HyperTerminal will show RING RING when it sees an incoming call.
    And I think Freefone even knows it's ringing but decides not to tell me, this is the debug log:
    7/06/2009 7:41:04 PM: Out: [AT+CPAS;+CBC]
    7/06/2009 7:41:08 PM: Out: [AT]
    7/06/2009 7:41:09 PM: Out: [ATE0;+CSCS="8859-1";+CRC=1;+CLIP=1;+CNMI=2,1]
    7/06/2009 7:41:09 PM: In: []
    7/06/2009 7:41:09 PM: In: [OK]
    7/06/2009 7:41:09 PM: In: [AT
    7/06/2009 7:41:09 PM: Out: [AT+CSQ;+CPAS;+CBC]
    7/06/2009 7:41:10 PM: Out: [AT+CGMI]
    7/06/2009 7:41:11 PM: Out: [AT+COPS?]
    7/06/2009 7:41:11 PM: In: [ATE0;+CSCS="8859-=1;+CLIP=1;+CNMI]
    7/06/2009 7:41:11 PM: In: [ERROR]
    7/06/2009 7:41:11 PM: In: []
    7/06/2009 7:41:11 PM: Out: [AT+CPBS="ME";+CPBR=?]
    7/06/2009 7:41:12 PM: In: []
    7/06/2009 7:41:12 PM: In: [ERROR]
    7/06/2009 7:41:12 PM: Out: [AT+CPBS="ME";+CPBR=?
    7/06/2009 7:41:13 PM: Out: [AT+CPBS="SM";+CPBR=?]
    7/06/2009 7:41:13 PM: In: []
    7/06/2009 7:41:13 PM: In: [ERROR]
    7/06/2009 7:41:14 PM: Out: [AT+CPBS="DC";+CPBR=?]
    7/06/2009 7:41:14 PM: In: []
    7/06/2009 7:41:14 PM: In: [ERROR]
    7/06/2009 7:41:15 PM: Out: [AT+CPBS="RC";+CPBR=?]
    7/06/2009 7:41:15 PM: In: []
    7/06/2009 7:41:15 PM: In: [ERROR]
    7/06/2009 7:41:16 PM: Out: [AT+CPBS="MC";+CPBR=?]
    7/06/2009 7:41:16 PM: In: []
    7/06/2009 7:41:16 PM: In: [ERROR]
    7/06/2009 7:41:17 PM: Out: [AT+CPBS="ME";+CPBR=?]
    7/06/2009 7:41:17 PM: In: []
    7/06/2009 7:41:17 PM: In: [ERROR]
    7/06/2009 7:41:18 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:18 PM: In: []
    7/06/2009 7:41:18 PM: In: [ERROR]
    7/06/2009 7:41:19 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:19 PM: In: []
    7/06/2009 7:41:19 PM: In: [ERROR]
    7/06/2009 7:41:20 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:20 PM: In: []
    7/06/2009 7:41:20 PM: In: [ERROR]
    7/06/2009 7:41:21 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:21 PM: In: []
    7/06/2009 7:41:21 PM: In: [ERROR]
    7/06/2009 7:41:22 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:22 PM: In: []
    7/06/2009 7:41:22 PM: In: [ERROR]
    7/06/2009 7:41:23 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:23 PM: In: []
    7/06/2009 7:41:23 PM: In: [ERROR]
    7/06/2009 7:41:24 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:24 PM: In: []
    7/06/2009 7:41:24 PM: In: [ERROR]
    7/06/2009 7:41:25 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:25 PM: In: []
    7/06/2009 7:41:25 PM: In: [ERROR]
    7/06/2009 7:41:26 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:26 PM: In: []
    7/06/2009 7:41:26 PM: In: [ERROR]
    7/06/2009 7:41:27 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:27 PM: In: []
    7/06/2009 7:41:27 PM: In: [ERROR]
    7/06/2009 7:41:28 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:28 PM: In: []
    7/06/2009 7:41:28 PM: In: [ERROR]
    7/06/2009 7:41:29 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:29 PM: In: []
    7/06/2009 7:41:29 PM: In: [ERROR]
    7/06/2009 7:41:30 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:30 PM: In: []
    7/06/2009 7:41:30 PM: In: [ERROR]
    7/06/2009 7:41:31 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:31 PM: In: []
    7/06/2009 7:41:31 PM: In: [ERROR]
    7/06/2009 7:41:32 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:32 PM: In: []
    7/06/2009 7:41:32 PM: In: [ERROR]
    7/06/2009 7:41:33 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:33 PM: In: []
    7/06/2009 7:41:33 PM: In: [RING]
    7/06/2009 7:41:33 PM: In: [ERROR]
    7/06/2009 7:41:34 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:34 PM: In: []
    7/06/2009 7:41:34 PM: In: [ERROR]
    7/06/2009 7:41:35 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:35 PM: In: []
    7/06/2009 7:41:35 PM: In: [ERROR]
    7/06/2009 7:41:36 PM: In: []
    7/06/2009 7:41:36 PM: In: [ERROR]
    7/06/2009 7:41:36 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:37 PM: In: []
    7/06/2009 7:41:37 PM: In: [ERROR]
    7/06/2009 7:41:37 PM: Out: [AT+CPBS="BS";+CPBR=?
    7/06/2009 7:41:37 PM: In: [RING]
    7/06/2009 7:41:38 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:38 PM: In: []
    7/06/2009 7:41:38 PM: In: [ERROR]
    7/06/2009 7:41:39 PM: In: []
    7/06/2009 7:41:39 PM: In: [RING]
    7/06/2009 7:41:39 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:39 PM: In: [ERROR]
    7/06/2009 7:41:40 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:40 PM: In: []
    7/06/2009 7:41:40 PM: In: [ERROR]
    7/06/2009 7:41:41 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:41 PM: In: []
    7/06/2009 7:41:41 PM: In: [ERROR]
    7/06/2009 7:41:41 PM: In: [RING]
    7/06/2009 7:41:42 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:42 PM: In: []
    7/06/2009 7:41:42 PM: In: [ERROR]
    7/06/2009 7:41:43 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:43 PM: In: []
    7/06/2009 7:41:43 PM: In: [ERROR]
    7/06/2009 7:41:44 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:44 PM: In: []
    7/06/2009 7:41:44 PM: In: [ERROR]
    7/06/2009 7:41:45 PM: In: []
    7/06/2009 7:41:45 PM: In: [RING]
    7/06/2009 7:41:45 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:45 PM: In: [ERROR]
    7/06/2009 7:41:46 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:46 PM: In: []
    7/06/2009 7:41:46 PM: In: [ERROR]
    7/06/2009 7:41:47 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:47 PM: In: []
    7/06/2009 7:41:47 PM: In: [ERROR]
    7/06/2009 7:41:47 PM: In: [RING]
    7/06/2009 7:41:48 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:48 PM: In: []
    7/06/2009 7:41:48 PM: In: [ERROR]
    7/06/2009 7:41:49 PM: Out: [ATD;]
    7/06/2009 7:41:49 PM: In: []
    7/06/2009 7:41:49 PM: In: [ERROR]
    7/06/2009 7:41:50 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:50 PM: In: []
    7/06/2009 7:41:50 PM: In: [ERROR]
    7/06/2009 7:41:51 PM: In: []
    7/06/2009 7:41:51 PM: In: [RING]
    7/06/2009 7:41:51 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:51 PM: In: [ERROR]
    7/06/2009 7:41:52 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:52 PM: In: []
    7/06/2009 7:41:52 PM: In: [ERROR]
    7/06/2009 7:41:53 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:53 PM: In: []
    7/06/2009 7:41:53 PM: In: [ERROR]
    7/06/2009 7:41:54 PM: In: []
    7/06/2009 7:41:54 PM: In: [RING]
    7/06/2009 7:41:54 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:54 PM: In: [ERROR]
    7/06/2009 7:41:55 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:55 PM: In: []
    7/06/2009 7:41:55 PM: In: [ERROR]
    7/06/2009 7:41:56 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:56 PM: In: []
    7/06/2009 7:41:56 PM: In: [ERROR]
    7/06/2009 7:41:56 PM: In: [RING]
    7/06/2009 7:41:57 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:57 PM: In: []
    7/06/2009 7:41:57 PM: In: [ERROR]
    7/06/2009 7:41:58 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:58 PM: In: []
    7/06/2009 7:41:58 PM: In: [ERROR]
    7/06/2009 7:41:59 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:41:59 PM: In: []
    7/06/2009 7:41:59 PM: In: [ERROR]
    7/06/2009 7:42:00 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:42:00 PM: In: []
    7/06/2009 7:42:00 PM: In: [ERROR]
    7/06/2009 7:42:01 PM: Out: [AT+CPBS="BS";+CPBR=?]
    7/06/2009 7:42:01 PM: In: []
    7/06/2009 7:42:01 PM: In: [ERROR]
    I’ve highlighted where it 'sees' the incoming call.
    So my questions are:
    If their a way to force the audio gateway use even when a call is triggered or answered by the DUN connection?
    Why doesn't Freefone see the incoming call?
    Are all the errors at the start simply Freefone requesting things like call list and contacts that Windows mobile does not understand?
    For what it's worth, I really have read through all 400 odd posts, and I’ve ha d a good Google on at command sets.
  9. #459
    Jun 2009
    ooops double post, have edited this one.
  10. #460
    Jan 2007
    Any ideas how to execute a command when phone connects to Freefone?
    looking for a way to to execute a command when freefone connects to a phone. I can see from skintool that freefone regularly sets a label which contains OFF and ON. any way i can check the string in regular intervals and set a variable true false??
    any ideas welcome...
    what i am basically trying todo is that as soon as my carpc detects the phone in range via blue tooth to open the doors via fusionbrain...
  1. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 06:06 AM
  2. Can roadrunner be full screen?
    By black06stang in forum Road Runner
    Last Post: 05-09-2006, 09:06 AM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
  4. Replies: 4
    Last Post: 02-18-2005, 12:11 AM
