FreeFone 1.3 Full integration with Roadrunner
Version 1.3 alpha
http://www.freedrive.co.uk/freefone.jpg
This comes fully packaged with everything thats needed for full integration with roadrunner. I have done a example with the bvm2 skin which everyone should have.
The Foneind.swf (flash file) can be placed on any skin and will show the battery / signal level. To include this on any skin simple place this in the .skin file..
L,0,0,0,0,0,0,0,18,"Arial","CUSTOMFREEFONE", ""
F,9,29,102,31,"Foneind.swf" <--- being the flash indicator, place where you want it
What will this now do ?
Once freefone is running, when you get a call coming in, it will auto change to the fonecall.skin and pause the music. If you have a picture named the same as the number calling it will show it. Its quite simple once you have seen it working :-)
I have included 2 folders in the zip, one is ready to just be copied over to the bvm2 skin folder and the other is just the standalone. (both .exe are the same)
you WILL need to edit the menu.skin in the bvm2 to call freefone instead of phonocontrol, but instructions on howto do this is in the readme.txt
let me know how you get on
Grab it from my site.
Cheers
CdR
