Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: road runner not loading anymore, just hangs.
  1. #11
    May 2006
    same here, installeed uninstalled..
    whats going on.. only other option is to try another frontend..(i love RR but its not worth a Windows reinstall)
  2. #12
    Jan 2007
    East Central FLA
    Just my $0.02, but I have doubts that it's a windows problem, or a Road Runner problem.
    A problem I have encountered is with Adobe products and their install/remove software. Both Adobe and Symantec (Norton Anti-virus) leave behind a good many things after telling windows to remove the product. It's almost impossible to go "back" a version. I experienced this when trying to install Adobe Acrobat Pro V6, over the top of Adobe Acrobat Reader V7.
    The only solution I know is to remove the Adobe (or Symantec product), then using a program (or manually) edit the Windows registry to clean the system of all traces.
    If, as I have assumed, the issue is not with folks who have a V9 flash, then install a V8 flash, my apology for wasting bandwidth.
  3. #13
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Do a search for a stand alone version of flash. If you try to install the browser plugin from Adobe it won't work. Here is the one I used
    Download Flash Player 9 (Complete Standalone Installer) - free download of the full Flash Player installer
  4. #14
    May 2006
    mine wasnt based on the flash plug in, but have the same problem (i was messing about with stuff)
    anyway i re-installed it as it wasnt working and it still didnt work
    got a fresh XP install and should be fine now
  5. #15
    Registered User
    Aug 2004
    mine freezes up sometimes for no reason too .. but all i do is reset the computer. wierd
  6. #16
    May 2007
    Roadrunner locks just after starting to load winamp
    Evening all, first post and sorry to say it's one needing your help...
    Starting road runner I get the roadrunner splash screen indicating "Starting Winamp", here the windows error sound and loose the start bar across the bottom of the screen. Three finger salute brings up Task Manager showing roadrunner @ 95% CPU utilization. Only way to correct the start bar problem is to restart.
    Some info and steps I've already tried:
    1. Using latest version of Roadrunner (4/11/2007) - this of course is on the soon to be installed machine, two other installations, one on a similar e-pc42 and another on a IBM 240x laptop run fine, same skins and external components. Even the problematic flash skin mentioned below works fine on both, just not the one going into the car.
    2. have removed flash, winamp (v.2.95) and roadrunner multiple times, uninstalled using the flash remover, have yet to try the regedit method of clearing every instance of flash, although I have done the regedit for roadrunner and winamp...
    3. Saw another post recommending flash 8, have tried that to no avail. Also another suggestion was to kick back the hardware aceleration a notch, no joy there either.
    4.Had been running fine, was trying a flash type skin with some funkiness, didn't like so switched back to Chuck's...shut machine down and now bupkiss.
    ( remember I've unistalled roadrunner and used regedit to remove all instances from registry, so even the skin from straight out of the shoot is fracked up)
    5. one other issue was I did install XP SP2 just after patch Tuesday this month... are there known issues with SP2?
    6. Application log shows the following 2 error messages each time roadrunner starts and locks:
    Event ID:1002
    Hanging application RoadRunner.exe, version 1.0.0.0, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
    Event ID:1001
    Fault bucket 31461586.
    7. reloading the OS may be the only fix, but it sure would be good to find the root cause and save others from this sand trap...
    suggestions anyone? Thanks for your time.
  7. #17
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    1) Re-register GDIPluswrapper (regsvr32 GDIPluswrapper.dll)
    2) Run RRConfig...& check all settings/paths...specially skin paths.
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  8. #18
    May 2007
    Wizz, thanks for the fast response,
    1) Re-register GDIPluswrapper (regsvr32 GDIPluswrapper.dll) Done
    2) Run RRConfig...& check all settings/paths...specially skin paths. Done
    Still no joy...what is the debug mode switch, perhaps I can get the info I need to fix this there...?
  9. #19
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i have this same issue outta the blue with my home pc... i dont use road runner much on there though.
    Live mp3Car Facebook Chat
  10. #20
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by MaxPeck View Post
    debugmode=true ( in rr.ini )
    Enables Creation of debug.txt with mixer info, command sequences, errors etc.
  1. Audio gatway issues with Road Runner and Phoco
    By Cruizer in forum Road Runner
    Last Post: 03-15-2006, 11:06 AM
  2. problems with video + road runner.
    By nealric in forum Road Runner
    Last Post: 01-14-2006, 10:37 PM
  3. Road Runner Setup
    By zaid175 in forum Road Runner
    Last Post: 06-24-2005, 06:00 PM
  4. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 02:54 PM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 01:30 AM
