Is it the problem with IG or with RR?
In RR, the only local setting is for weather and none related to GPS (other than unit miles vs kilometer).
In iG you can change it in the set destination via Address.
I found my issue main issue.. I didn't know the iGLaunch existed.... but I still can't do the following
I cannot change the Country from USA to Canada in my GPS settings in RR... is there an *.ini file I can change?
when I change it to Canada and save, when I open it, it's back to USA.
Thanks in advance
Vin
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
no it's in RR, THis post was for another issue but I figured it out.. so I decided to recycle the thread...
In RR setup if I change the Country and State settings and save... when I re-open it's back to USA and blank....
If it really has nothing to do with my GPS functionality then I won't worry about it.....
BTW: I've seen your setup on MatrixOwners.... clean job.
Vin
Carputer works... but will never be complete....
