each plugin has its own specific settings and instructions on how to get them to work with RR.
I do feel your pain though, there should be a standard method with some rules to follow that make the whole process as easy as possible.
First would be a plugins folder where all plugins should be installed and auto loaded from instead of the put file anywhere you want method. But thats a whole other thread topic.
Best suggestion is to just do what said plugin says to do to get it to work, for each plugin you want to use.
LinkBack URL
About LinkBacks
you will come far on this. Also the FAQ on installing the CDRip-plugin describes the install process (but for a newb like me can't compare RRMobile in the process).
