Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: Release: Navigon Voice Guidance Attenuation
  1. #21
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You can do this by setting the delay time from 0 to 60 sec.
  2. #22
    Aug 2006
    Quote Originally Posted by Ti-ejtsch View Post
    Hello,
    now itīs working :-) I have to say you made a great work!
    But one thing Iīm missing. Something like:
    Hold GPS screen after saying directions for xx seconds than switch to last screen.
    Sorry for my bad english, I hope you understand!!!
    Ti-ejtsch
    Hi,
    I'm glad you have it working now... as MGD has mentioned you should be able to set the delay on NaviMon's main settings... (please check you have the version I posted on 20th Jan)
    Cheers
    Neil
  3. #23
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Any chance of adopting your program to work with other GPS software ?
    The road is long but we are getting there.
  4. #24
    May 2005
    Germany
    @swift gti
    Time is working with following command:
    CMD OFF: GPS||WAIT;xx
    xx = seconds bevor switching to LASTSCR
    With this settings, NaviMon is working great for me:
    Trigger if volume...: 50%
    Muted volume: 255
    Unmuted Volume: 0
    Show guidance screen...: True
    Cmd on: AUDIO
    Cmd off: GPS||WAIT;10
    Delay: 0
    When I change delay to 5 and donīt write the command "WAIT;xx" I donīt have the effect I want.
    swift gti thanks a lot you made a great work !!!
    Ti-ejtsch
  5. #25
    Aug 2006
    Hi, Glad you have it working for you.. interesting that it works ok as the values you have seem to be the wrong way round..
    I would have thought the following settings would be required for it to work as designed:
    Trigger if volume = 50%
    Muted Volume = 0
    Unmuted Volume = 255
    Show guidance screen = True
    Cmd On: GPS
    Cmd Off: Audio
    Delay 10
    That way when guidance speaks you will get
    - shown the GPS screen for the whole of voice guidance + 10 extra seconds
    - winamp muted while voice guidance speaks
    - taken to Audio screen after voice guidance + 10 seconds
    But if its working then thats good
    @swift gti
    Muted volume: 255
    Unmuted Volume: 0
    Cmd on: AUDIO
    Delay: 0
    Ti-ejtsch
  6. #26
    Aug 2006
    Quote Originally Posted by tolisn View Post
    As long as the GPS software lowers windows wave volume then there is no alteration to code needed.. if it doesn't lower the volume then i'm afraid I have no way to detect when guidance has started, short of using SDK's etc..
    Cheers
  7. #27
    Aug 2006
    Small update for a problem I found while using the delay feature for cmd off...
    If you have changed the default settings just overwrite ONLY the NaviMon2.exe to keep your settings.
    Attached Files Attached Files
  8. #28
    Nov 2005
    i have another problem regarding volumes (with sygic drive):
    i am often listening very loud (bass) music during driving. if then the voice jumps in, it almost blows my ears (and loudspeakers). you can easily listen techno and rap at high volumes but voices only tend to distort.
    is there a way to have voice commands to be outputted at 50% of the current music volume (interrupting/pausing the music) and then resume full power music playback?
    sygic is reducing the volume constantly to i.e. 50% so music playback then also goes with that low volume
  9. #29
    Aug 2006
    This program will not work correctly with Sygic drive.
    I'm currently looking into a method of detecting when Sygic speaks so that I can create a solution for that..
    I need to do some investigation on how to monitor API call's as Sygic makes call's to Winmm.dll when it speaks...
  10. #30
    Nov 2005
    looking forward for a solution.
    it is blasting my ears when speaking directions. so i had to turn off any sound coming from sygic drive but this also mutes warnings of radars etc. hhmm too bad. why are so simple things never working. why do they (sygic) reduce the overall volume and not setting it back after the message? hmm engineers withoug cars:-)
  1. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 04:29 PM
  2. SpeakEasy Voice Recognition - Release 0.9.1
    Last Post: 06-03-2005, 06:19 PM
  3. SpeakEasy Voice Recognition - Release 0.9.1
    By ruairi in forum Road Runner
    Last Post: 06-02-2005, 04:57 AM
  4. Voice packs for coming release
    By naveedh in forum Map Monkey
    Last Post: 01-03-2005, 04:51 PM
  5. Replies: 2
    Last Post: 10-11-2004, 07:38 PM
