Page 5 of 5 FirstFirst 12345
Results 41 to 46 of 46
Thread: Release: Navigon Voice Guidance Attenuation
  1. #41
    Jul 2006
    Brisbane, Australia
    Just for the record, I've been using this for a while and it works well. The only issue have is that if you have the GPS window open and a voice prompt occurs, it switches back to the last screen open, so to do anything in the GPS, this is a bit annoying.
    I think the code shoul look something more like this psuedo-code:
    Code:
    If GPS_voice_is_activated
    If Current_Screen <> GPS_Screen
    Select Last_Screen
    EndIf
    EndIf
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
  2. #42
    Constant Bitrate lacning74's Avatar
    Apr 2008
    Quote Originally Posted by RanDJ8487 View Post
    Has anyone tested this with Garmin Mobile PC Software?
    couldn't get it to work with my garmin mobile. i don't think it lowers the wave line.
  3. #43
    Jan 2008
    San Francisco
    One option for Garmin MobilePC (if text-to-speech is not used) would be to monitor the NTFS access time of the voice files. Whenever the access time is updated, you know the GPS software is speaking. The downside is that you have to enable the NTFS last file access mode, which is not so good if running EWF with flash disks.
    This approach is taken by the EniCar front end software, and I use it successfully with Garmin MobilePC.
    If text-to-speech is used, Garmin MobilePC is just making windows API calls to the MS Speech API, so would need to figure out how to intercept those to detect guidance commands. BTW, if anyone knows how to do this, I'd appreciate some pointers!
    Thanks.
  4. #44
    Jul 2006
    Brisbane, Australia
    Monitoring the file access time would be very easy as there are API's to monitor a folder and notify of updates to the folder. Google "Folder Watcher". Here is a starter for you.
    http://www.relisoft.com/win32/watcher.html
    RodW
  5. #45
    Jan 2006
    I'm just testing it on my desktop - I haven't got RR installed here. It doesn't work for me If I double-click on NaviMon2.exe to run it, it causes an error: "navimon2 has encountered an error and needs to be shut down".
    Any ideas?
  6. #46
    Jul 2006
    Brisbane, Australia
    From the first post:
    You will need to have .net framework installed and place the executable into the your roadrunner folder (Guino's exec.exe must also be present as this is used to tell winamp to lower its volume)
    At a guess I'd say you need to install .net which is a free download from Microsoft.
    RodW
  1. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 03:29 PM
  2. SpeakEasy Voice Recognition - Release 0.9.1
    Last Post: 06-03-2005, 05:19 PM
  3. SpeakEasy Voice Recognition - Release 0.9.1
    By ruairi in forum Road Runner
    Last Post: 06-02-2005, 03:57 AM
  4. Voice packs for coming release
    By naveedh in forum Map Monkey
    Last Post: 01-03-2005, 03:51 PM
  5. Replies: 2
    Last Post: 10-11-2004, 06:38 PM
