I have tried everything under the sun to try and figure out another way to close autoit. I even tried to add hot keys to it (^%X), which worked with the keyboard, but I could not get RR sendkey to do it.
So the only thing I can suggest is to use autoit window info and see if the window name is the same as the pic when you touch the icon – Autoit v3
LinkBack URL
About LinkBacks
(Running it using the button does work ok!)
