Results 1 to 7 of 7
Thread: Getting Events from the COM SDK
    Oct 2003
    Copenhagen, Denmark
    Hi Guino
    I am trying to get info from RR about what screens are active in RR using the SDK. I can send commands just fine with the COMSend function. But how do i get RR to tell my application that someone just pressed AUDIO, GPS, whatever.....button and/or command has been executed ?
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
    Oct 2003
    Copenhagen, Denmark
    I tried adding something like this to my menu.skin which in theory should make COMReceive fire and send AUDIO to my application, which is called RR_Joystick :
    B01,11,73,339,106,"AUDIO||SENDMSG;RR_Joystick;AUDI O","Audio player" But i get no firing of COMReceive
    Oct 2003
    Copenhagen, Denmark
    in modSDK.bas i did this :
    Public Sub COMReceive(Data As String)
    Text1.Text = "Event" & " " & ":" & Data
    End Sub
    Just to show the data as it is received, but i get nothing
    Oct 2003
    Copenhagen, Denmark
    Nobody knows? or has sample code ?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can simply use "SENDMSG" to send messages from the skin to your plugin.. just look up the command in skin commands.txt .. You'll need to hook a window of your plugin before receiving any messages.. check the SDK example application -- it has plenty of examples... You can actually monitor all the commands being executed in RR if you make an extension plugin.
    Ride Runner RR's Myspace
    Oct 2003
    Copenhagen, Denmark
    Ah, ok i see know. It seems i was trying to do this from the compiler....only works when the application has been compiled as far as i can tell.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You have to run the compiled version as the window hooks can sometimes crash VB.. If you're coding a plugin in VB6, I would strongly recommend using the Extension plugin interface, but that's still up to you.
  1. iGuidance SDK
    By Quattro in forum GPS
    Last Post: 06-23-2006, 07:37 AM
  2. SDK commands over the serial port ????
    By tolisn in forum Road Runner
    Last Post: 12-14-2005, 12:03 PM
  3. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 03:18 AM
  4. Developing Touchscreen SDK -- need feedback!
    By kevlar in forum Software & Software Development
    Last Post: 07-14-2005, 05:55 PM
  5. Replies: 9
    Last Post: 03-31-2005, 02:40 AM
