How to make Winamp TV Plugin work with RR
Guys, I have follwed the FAQ for installing the Radio and TV and the Radio worked but didnt have the TV to work the way i anticipated will work.
I have installed the Winamp TV plugin and I am using WinTV "Hauppauge the PCI one with FM"....Long story short.
I use WinTV2000 my TV work so I know the TV works.
I am using BMV2 skin.....I run RR and I click on Radio button and it works with no issues, click on TV button the skin load but nothing all there is on the left side is 1. SO i close RR. I run winamp and go to Play --> File --> and select one of the channels saved in my folder called TV preset and i can see the channel sound everything great so while the thing is running I run RR again and click TV button and the TV works no channels on the left side other than "1." but if i use P+ and P- i can scroll through the channels saved.....
Anyone know how can i fix the issue, its a hassle to go thru this each time i need to ues TV. I thought that the TV will work just like the radio, i click the button and i see all the channels that i saved and pick whichever i want to watch....
Like i said any help will be appreciated
