Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: How to make Winamp TV Plugin work with RR
    Constant Bitrate ramez75's Avatar
    Dec 2006
    Nazareth PA
    Guys, I have follwed the FAQ for installing the Radio and TV and the Radio worked but didnt have the TV to work the way i anticipated will work.
    I have installed the Winamp TV plugin and I am using WinTV "Hauppauge the PCI one with FM"....Long story short.
    I use WinTV2000 my TV work so I know the TV works.
    I am using BMV2 skin.....I run RR and I click on Radio button and it works with no issues, click on TV button the skin load but nothing all there is on the left side is 1. SO i close RR. I run winamp and go to Play --> File --> and select one of the channels saved in my folder called TV preset and i can see the channel sound everything great so while the thing is running I run RR again and click TV button and the TV works no channels on the left side other than "1." but if i use P+ and P- i can scroll through the channels saved.....
    Anyone know how can i fix the issue, its a hassle to go thru this each time i need to ues TV. I thought that the TV will work just like the radio, i click the button and i see all the channels that i saved and pick whichever i want to watch....
    Like i said any help will be appreciated
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Sounds like you need to point RRConfig to the TV path where you saved the TV Presets in winamp -- that's what it should list on the left side ... the "1." (empty list) indicates the path is wrong or RR Couldn't find any of the preset files in the folder you pointed RRConfig onto.
    Ride Runner RR's Myspace
    Dec 2006
    Nazareth PA
    guino, i did that, rrconfig "rr.ini" are set to the right path i made sure of that this was part of the instructions in the FAQ.
    Any other thing i can do?....like do i need to add something in the menu.skin eg: X, Winamp TV plugin or something of that sort.
    Dec 2006
    Nazareth PA
    Still no luck in making the TV working directly from RR TV button. I was thinking if a code is written using Autoit and link the TV button to it. So when i click the TV button it will open winamp and open a .tvc file inside the TV skin. Now i got to figure out how to write something like that.
    Dec 2006
    Nazareth PA
    Another thing i found out that in the TV preset folder i have a channels.ini when i open that file the only value in it is 0. I looked at the radio.ini that is in RR folder at it has my stations preset number in it. I dunno why only 0 is there
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Can you post your RR.INI and a screenshot of the folder (with visible path of it) and the files in it ? This is one of the simplest of the things to set up. If it's working directly in winamp, it should work fine in RR -- as long as your skin works -- which skin are you using by the way ?
    Dec 2006
    Nazareth PA
    I am using BMV2, i will post them within the hour. Thanx for the reply
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    This is what I did to get WinampTV works.
    - Install TV tuner card/driver (USB2 for me).
    - Download WinampTV plugin and install.
    - Run winampTV and configure the pluin, scan for channels.
    - Open RR.ini and add the path (tvpresets=D:\WTV_stations\ for me) to where the plugin save channel info.
    - Create TV skin for RR.
    That's all.
    When I open channels.ini, it has 12 which is corresponding to 12 *.tvc files
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2006
    Nazareth PA
    Guino below is my rr.ini
    voice=false
    musicpath=C:\Documents and Settings\Ramez\My Documents\My Music\
    videopath=C:\Documents and Settings\Ramez\My Documents\My Videos\
    dvdpath=C:\Program Files\CyberLink\PowerDVD\PowerDVD.exe
    dvdname=Power DVD
    launchpath=C:\Road Runer\LAUNCH\
    winamppath=C:\Road Runner\Winamp\
    skinpath=C:\Road Runer\skins\BMV2\
    nightskin=C:\Road Runer\skins\BMV2\
    mpcpath=C:\Road Runner\mplayerc.exe
    screentype=16:9
    videoautohide=true
    videohidetime=4
    videofiles=.AVI,.MPG,.MPEG,.RM,.RAM,.VOB,.ASF,.WMV
    audiofiles=.M3U,.MP3,.WMA,.OGG,.AAC,.MPC,.VQF
    hidemouse=true
    albumart=*.txt
    useid3=3
    showid3playlist=false
    showid3browse=false
    gpsmode=2
    gpsport=0
    mapmonkeypath=C:\DestinatorApps\Map Monkey\MapMonkey.exe
    gpspath=C:\Program Files\Microsoft Streets & Trips\STstart.exe
    gpsname=- Microsoft Streets & Trips
    exitmode=1
    showicons=true
    showextensions=false
    titlesafter=-
    listfollowssong=true
    resumemusic=2
    audiorepeat=on
    audioshuffle=off
    singleclickaudio=true
    gammamode=1
    gammapath=C:\Road Runner\Gamma\GammaControl.exe
    dateformat=MM/DD/YY
    timeformat=HH:MM AM/PM
    id3listformat=%artist% - %title%
    id3browseformat=%artist% - %title% - %genre% - %album%
    mastervolmap=0
    listnumbers=true
    noformat=false
    hidewinamp=true
    tvpresets=C:\Program Files\WinTV\TV preset\
    tvline=1
    visuname=!Winamp Gen!AVS
    overspeed=80
    scrollmode=2
    builtinvideo=true
    disableinternat=true
    locale=0
    hidetaskbar=false
    hidedesktop=false
    radiomode=3
    radiatorpath=C:\Program Files\WinTV\
    radioline=1
    playlistpath=C:\Documents and Settings\Ramez\My Documents\My Music\
    lazytag=false
    allowallfreqs=true
    browsertype=1
    browserpath=C:\Program Files\Internet Explorer\iexplore.exe
    mapvol=50
    standardphonebook=0
    maxcalllistentries=100
    xmport=2
    xmline=1
    singleclickxm=true
    debugmode=true
    hibernateaware=true
    enableclipping=true
    soundcard=0
    nozoom=0
    ipoddrive=Click here to set drive
    usegestures=false
    leavemousealone=false
    hibernatereload=true
    forcehibernate=false
    closeapps=false
    cityweather=Savannah, Georgia
    weatherunits=USA
    /gpspath=C:\Program Files\Microsoft Streets & Trips\Streets.exe
    picspath=C:\Documents and Settings\Ramez\My Documents\My Pictures\
    gpsgaspath=C:\Road Runner\GPSGAS\
    transition=1
    Dec 2006
    Nazareth PA
    Below is my channels.ini
    0
  1. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
