You can turn on and off gestures completely, or define an area you do not want gestures to work. For instance on your GPS Map area(Gestures prevents you from dragging the map in such a screen.) You can also make a few or as many gestures as you want. For instance I do not use gestures to "type" and have removed all the alphabet codes from the gestures.ini.
You can change the "Red Ball" to anything you like. Just create a "GESTURES.BMP" image. You can then place this in your skin folder of your choosing. This allows each skin to have a gestures image that more matches the skin in use.
LinkBack URL
About LinkBacks
. i still need to figure out how to make everything not like pause/freeze while i do gesters
