Results 21 to 30 of 37
Thread: AutoIt
  1. #21
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    command lines can be sent on the fly? i dont think it works like that
    Live mp3Car Facebook Chat
  2. #22
    Low Bitrate rjankowski's Avatar
    Oct 2006
    TN/KY Home is Houston
    you would probably have to put that all in a while 1 loop and have it sleep for 100ms or so (i would think)
    It works!!
    Almost all of the time too!
  3. #23
    Apr 2006
    Ah, so you're talking about having the .exe running and sending commands to it? Interesting. I was thinking more along the lines of having each key run the .exe. You'd have to put it to the test but with a file that small i don't think it'd have any problems keeping up with your onscreen typing. (i.e. running twice per second)
  4. #24
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I don't think that I'd do
    I'll take a gander at it...
    The only thing that I can think of off the top of my head, would be to use the receiver.au3 from the source.
    Prob a better way, just don't know it yet. If you figure out something post it here cause it could be handy for some other things....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #25
    Apr 2006
    Just came accross this which may be just the ticket. hotkeyset. I haven't had a chance to place with it but it looks like if you wrote something similar to:
    $key = Hotkeyset("k","Keyboard") would run a keyboard function that you wrote where you could use $key as the keypress. There would be a lot of code because you would need one for each osk key but you should be able to use one variable.
  6. #26
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Thats thinking outside the box...
    But I don't think that would work very well...I have used that before and the only prob is that it set a global hotkey. So, if you had any shortcut keys in your keytbl.ini, there would be conflict between the two, and the autoit one would prevail because it setting the hotkey in windows enviroment(global).
    And in your example the $key just would just indicate wheather autoit was able to set the hotkey or not by returning a '0' for couldn't set or a '1' for set..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #27
    Apr 2006
    What in the world am I doing wrong?
    I'm trying to send a label to RR using the following:
    $rr = ObjCreate("RoadRunner.SDK")
    $rr.Execute("SETLABEL;intradio1;" & $title)
    The label shows up for about 1/2 a second and then it's gone. If I put it in a loop then it blinks (as it updates). Any ideas or ways around this?
  8. #28
    Woodbridge, VA
    Blog Entries
    53
    ur setting a label in the wrong format. It should read "SETLABEL;!intraradio1;" & $title.
  9. #29
    Apr 2006
    Unless I missed something, all you added was a ! in front of the label.....I can't that to send the label at all. The other way at least blinked.
    EDIT: It did have something to do with the custom portion though. Changed the label to customradio and it fixed the issue.
  10. #30
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Quote Originally Posted by 1Munkey View Post
    Glad you figured it out, I as just about to shoot you a message about the labels. I just remembered I had the same issue. Everything working now?
  1. Parallel port relay control in RR using Autoit?
    By momanz in forum Road Runner
    Last Post: 04-03-2009, 10:20 AM
  2. Thoughts on Autoit X
    By lostreception in forum Software & Software Development
    Last Post: 09-13-2006, 01:33 AM
  3. Replies: 3
    Last Post: 04-24-2006, 04:53 PM
  4. AutoIT
    By ashgrovered in forum Coders Corner
    Last Post: 03-16-2006, 09:29 AM
  5. Any AutoIt script experts out there?
    By mindracing in forum Centrafuse
    Last Post: 08-11-2005, 03:19 PM
