Results 1 to 9 of 9
Thread: Flash in Road Runner
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Unhappy Flash in Road Runner
    How come that some Flash files just wont run in Road Runner?
    Also, when I run a Flash File outside Road Runner it uses ALOT less CPU Cycles when embedded. Is the there a way to change some setting?
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Quote Originally Posted by MGD View Post
    I don't know if this thread can help you. But its worth a shot Notice :- Flash speed with albumart
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I remember adding an option to make the Flash object "SOLID" which allowed it to be much faster while embbeded in RR. The transparancy is what tends to make Flash slow down, but (sometimes) also allows for cool looks and integration between the skin and Flash.
    EDIT: Just add ,SOLID at the end of the normal F definition
    Ride Runner RR's Myspace
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Just added ,SOLID to the Flash file but the clock is still not working embedded. Why is it running outside but not inside of Road Runner?
    Constant Bitrate Playerbeat's Avatar
    Apr 2005
    San Jose, CA
    i've never had a problem. can you post the source?
    7" TouchScreen Carputer
    Rockford Fosgate 1501BD and Rockford 551s
    12" MTX 9500 in a SS* or a 12" Brahma in a SS*
    ZAPCO COMPONENTS in front and RFs in rear
    2 YellowTops and a 200amp Iraggi Alternator
    *Snell Shell box from nolteaudio.com
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    how are you embedding it? There are 2 ways i know of, one is creating the flash file as a .exe and embedding it as a normal application and the other is using the F line in the .skin.
    We cant really say why its not working till we know how you are doing it and what your command looks like.
    That skin looks sweet btw.
    beer replenishment fund
    mp3car live search
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Unhappy
    I tryed it both ways. First I used the F definition and it embedds just fine but the clock is not working. Then I used the A definition with the window title as "Macromedia Flash Player 7" that was winspector tells me then the clock works but shows the menu bar. Look at the screen shot. othe clocks work but some don't.
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    If you have the .fla file you can add this- fscommand("showmenu",false) –to it and get rid of the top menu for the exe one. But do not run as a .swl after that or RR will talk and say show menu.
    2001 S10 ZR2
    Chucks Skin - to old
    Constant Bitrate Beezer's Avatar
    Oct 2006
    Thx Guino. Your ",SOLID" tip along with CDRSkulls "J" tip have made the Xeon skin usable on my 1Ghz carpc
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 01:40 PM
  2. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 10:50 AM
  3. Road Runner Sound Problem
    By Mick300ZX in forum Newbie
    Last Post: 05-23-2006, 08:45 PM
  4. Can I watch video into a Road runner ?
    By shinjetko in forum RR Bug Tracker
    Last Post: 05-19-2006, 01:31 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
