Results 1 to 8 of 8
Thread: Add to current playlist?
    Apr 2006
    Ok so I must be having a pure stupidity moment because I've been trying to get this to work for hours now and can't figure out what I'm doing wrong. For some reason when I press "add1" it adds the song to the current playlist but changes the name of the playlist to "on-the-fly" thus preventing me from saving the updated changes.
    GOAL: I'm trying to add a song from the audio_browser to the currently playing playlist.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    How about a button that saves the playlist after you've modified it?
    Look up "SAVELIST" or "ADDTOLIST" commands in RR skin commands.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    This unfortunately is the way that RR works. If you have a playlist you load called "My Music", when you ADD+ it is no longer that playlist, as you have modified it from when it was loaded, and is now "On The Fly".
    You can check out my skin (In my signature) and get some ideas on how to add a lot of custom stuff for playlists. It will allow you to replace a playlist, create a new one, rename, delete and manage playlists pretty well.
    My Fiero Build Thread
    Dec 2008
    Quote Originally Posted by JohnWPB View Post
    I have the same problem when adding songs to current playlist. Can have a way to add songs to current playlist without change it's name? What I want is to add songs to current playlist.
    MySQL Error
    Oct 2004
    JUST ADD THEM... then SAVE the playlist, as the NAME it as it was...
    next time you LOAD that playlist... it will be named as u had it, and have the new songs
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Dec 2008
    Quote Originally Posted by mitchjs View Post
    The problem is that the current playlist name is changed to "ON-THE-FLY Playlist" when I added the new songs. So the original playlist was not updated by the following code:
    "SETVARBYCODE;LISTNAME;PLAYLIST||SAVELIST;$playlis tpath$$LISTNAME$.m3u"
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    There is no way to add a song to a named playlist and have it retain the same name. As I mentioned above a few years ago, if you have a playlist called "Favorite Songs" and you add something to it, it is no longer the "favorite songs" playlist, as you have modified it.
    You simply need to have skins and code in place to work around it. The way I did it in DFX is when you hit the "save playlist" button, it loads a screen that shows a list of all of your playlists. In that screen are buttons for "New playlist" "replace playlist", "Rename playlist" ect.
    So in the case you add a song, press save playlist, the new screen shows all your playlist, and you select "favorite songs" from the list of playlists, and click "Replace Playlist". Now the favorite songs playlist contains the original playlist, plus the songs you added.
    EDIT: There is another work around that may work for you. If you load a playlist, on the same button that you load the list from, you could add code to save that playlist name to the skin.ini as a variable, and update that variable in memory as well.Maybe name it like "LastPlaylist" or something. on your "Save Playlist" button you could then use this code:
    SAVELIST;$playlis tpath$$LastPlaylist$.m3u
    The only drawback to that, is anytime you saved a playlist with that code it would always overwrite whatever the last playlist that you loaded was.
    Dec 2008
    Thanks, I use this method, it works well.
  1. Music navigation
    By upspace in forum StreetDeck
    Last Post: 02-01-2007, 12:49 AM
  2. Replies: 0
    Last Post: 01-21-2007, 05:29 PM
  3. version 1.0.5.8 queue playlist bug
    By bembowe in forum StreetDeck
    Last Post: 11-18-2006, 07:27 PM
  4. How do you add songs to the current playlist?
    By S4Per in forum Road Runner
    Last Post: 06-26-2005, 11:06 PM
  5. Remote Playlist Manager for Frodoplayer - 1.0 Beta 1
    By PatO in forum Software & Software Development
    Last Post: 03-17-2005, 02:58 AM
