Make certian that your "Screen Physical Aspect Ratio" radio button is set at 16:9 instead of 4:3.
Alternatively, Make certian you are using a skin that was made for widescreen.
What am i doing wrong?
I set me carpc to run at 800x480 i could watch movies (with Media player) without stretching the pixels.
Although, when i run Road Runner i cannot see everything in my screen.
So far i tried the following:
-Set the resolution in config at 800x480
-set the resolution in skin general.ini 800x480
but the problem is still the same?
see attachments for what i see
MAZDA RX8 WinningBLUE TypeS 250bhp
Xenarc integrated to Navigation
Carputer in early development
physical aspect ratio is set to 16:9
i am using the skin that comes with the installation of RR (BMV2 i think)
it's a 800*600 skin ! So bottom of screen is scratched
search for another skin : perhaps Lsxvoid : it can be used both resolutions standard 800*480 and stretched.
Yes, the BMV2 skin is 800 x 600 but that does not matter. You can use any size skin with any resolution with RR. It may look stretched ot squashed, but you can fit it to the screen. RR has a built in scaling ability.
Portion of the general.ini file in the Skin directory, in this case:
Road Runner\Skins\BMV2\general.ini
To force an 800 x 600 skin to 800 x 480, change the general.ini to read:Code:OriginalWidth=800 OriginalHeight=600 ShowWidth=800 ShowHeight=600 XPosition=0 YPosition=0
The first 2 lines are the actual dimensions of the skin's jpg's. The 2nd 2 lines need to be set to your screen resolution, to resize it to fit the current display resolution.Code:OriginalWidth=800 OriginalHeight=600 ShowWidth=800 ShowHeight=480 XPosition=0 YPosition=0
My Fiero Build Thread
