Results 1 to 5 of 5
Thread: Roadrunner changing volumes?
    Feb 2007
    Im having a problem with roadrunner, the windows master volume is set about half way and when i lower the volume in roadrunner it lowers the master volume right down. The problem is though when you raise the volume in RR it doesnt raise the master volume making it really quiet still.
    Any ideas?
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Check your settings in the RR.ini file, use the RR config. Try setting or "map" the soundcard to "master" volume..
    Feb 2007
    Could you give me a little more info? I check in RR Config and couldnt see anything helpful. I'd like to figure this out so I can use RR instead of having to try something else.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You need to run the RRConfig.exe in the main Road Runner Directory and click on Music. Scrool down and select Map Master Volume To Control Line: and select Master Volume.
    I you want to do it manually, open RR.ini and change the line
    mastervolmap=0
    Feb 2007
    Ahh thanks mate, thats brilliant. I'll have a look in the morning. Hopefully if that works it'll only be the screen ghosting to sort out and its finished
  1. Replies: 13
    Last Post: 08-30-2007, 10:27 PM
  2. Mappoint and Roadrunner Error
    By 0statik in forum GPS
    Last Post: 07-06-2006, 12:46 AM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
