Make sure you don't have anything in the start command.
Also check Exectbl.ini that there is nothing in the "Onresume" line.
RR will not resume the last song played after close. In config the resume setting is set to always,repeat off,shuffle is on but it still does not work. If I just open winamp without RR then change to a different song then close it winamp works fine. But when I use RR it goes to the top of the playlist.
Any ideas what is messed up?
Michael
Shuttle Sk41g,Xp Pro,2.4ghz Amd,250gb Wd 7200 Rpm Hd,2gb DDR Ram,Ati Radeon 9250,Sound blaster external,CarPC Pro v.2.5d SD Controller,7" Xenarc 700TSV
1.)Orion 2500d Amp
1.)Orion 15" h2 Sub
1.)Orion 8004 Amp
2.) Sets Orion Components - P-SERIES
1.)Orion 2500d Amp
1.)Orion 15" h2 Sub
1.)Orion 8004 Amp
I just reinstalled RR binary now it works so some setting was messed up or some file must have been corrupted.
Michael
1.)Orion 2500d Amp
1.)Orion 15" h2 Sub
1.)Orion 8004 Amp
