Results 1 to 9 of 9
Thread: Audio_player question
    Jun 2006
    I am having an issue with any song list in my audio player skin will not advance to the next song when the high-lighted song is complete also when I click next it jumps song as it want to sometimes three or more songs. It just acts like it want to replay that same song over for a sec and then stops.
    When I play the play list from my main menu it will cycle thru all of them and goes in the correct song number order. Thanks in advance for any tips.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    What skin are you using?
    Make sure you have the same commands in the audio_player.skin that you have in the menu.skin.
    Feb 2006
    What version of Winamp?
    5.13 is supposed to work the best with RR.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by EricE View Post
    Unless it has been updated, I thought it was version 2.95... Version 5 was hassle filled.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2006
    A little bit of this and a little bit of that is the skin and im using winamp 5.24. When I am in the main window and the audio browser they both work. Just not the audio player window as soon as the song finishes it pauses.
    Mar 2006
    Well this thread: Finally broke winamp 2.95 suggests 5.21, but that is an oddity. 2.95 seems to be standard. But since yours is pretty close, I don't think that is the problem, but installing 2.95 would reassure us.
    I think you should just double check your commands in the skin file as mentioned earlier. And did this ever work, and then stop, or never work?
    Apr 2006
    Try switch audio_player.skin to something like custom_player.skin. The "audio" function was designed to limit the coding of calling the screen, declaring the playlist, etc. so there may be something in there that causes the new version of winamp to be unhappy.
    Jun 2006
    That didn't work. It has something to do with the playlist itself if I just have it revert back without a playlist window it plays fine.
    Jun 2006
    I figured it out my ExecTBL was jaked up. Works good now. Thanks all for your help.
  1. heavy-duty OBD standards support question
    By Michael2006 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-07-2007, 05:13 AM
  2. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  3. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  4. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
