Results 1 to 9 of 9
Thread: Music not importing
    Mar 2006
    Music not importing
    My music isn't importing. The paths are all set correctly and i'm using winamp 2.9. Winamp will play the music outside of RR, but when RR starts up and I go into music I can only see the one song that was playing in winamp before RR, my library doesn't show up. Then, the buttons stop working. Can't try to import music, press play, or even return back to main screen.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    What skin are you using?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Yes, first what skin are you using. Secondly, there is no need to "Import" music in any way. RR simply looks at your music path, and displays what is in that path. It sounds like you are looking at a playlist screen, and not a "browser screen". The reason I say this, is if you simply see the current song playing, then that is your playlist, and not the directory with your music in it.
    Make sure you have the path in RR Config set to point to the path/location of your music.
    My Fiero Build Thread
    Mar 2006
    I'm using BMV2. The path is set to the location of my music, it worked once and then went back to not working. Basically, once i go into music, everything will stop working and I'll have to ctrl+alt+delete to close road runner.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by ssadiq View Post
    Hmmmm this COULD be a flash problem. If the correct version of flash is not installed on your machine, it can peg the machine at 100% CPU making it seem as everything has locked up. Try opening task manager, putting it off to the side if you can to keep an eye on the CPU usage when you load the music screen. BMV2 has a flash logo in the center of the main menu. If it IS pegging the CPU< then it would seem like pressing any button from the main menu is not working. I am not sure this is the problem or not but it's one thing to rule out.
    Mar 2006
    yea, i tried what you said and CPU usage is at 100%. so what flash version do I need?
    Mar 2006
    I found the sticky that deals with this issue, but this link isn't working:
    road runner roadrunner software car at rrdownloads.net
    Does anybody know where I can find this?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    It definitely sounds like a flash version problem then.
    Yes, the domain name expired. You can find the site HERE.
    Actually, first, I would just use Internet Explorer, and install the latest flash with it. (Installing through Firefox will not install the files for the rest of windows to use).
    If you do a search for "White box" and "Flash" in the forums, there are a lot of links and suggestions to get it up and working correctly.
    Mar 2006
    Thanks! It's working now.
  1. Importing Music
    By pb_blade in forum Road Runner
    Last Post: 03-13-2007, 02:16 PM
  2. Music Indexing
    By aforget in forum StreetDeck
    Last Post: 02-06-2007, 11:25 AM
  3. Importing Music
    By tangeray in forum Centrafuse
    Last Post: 08-25-2005, 04:49 AM
  4. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 10:08 PM
