Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 59
Thread: Pocket PC Remote for RoadRunner ?
  1. #11
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Hi m8, I dont want to be using winamp as it limits the controls, also since I've coded the standalone webserver in vb it wont support php sadly, just html and maybe dhtml or whatever it is, I want to stay away from flash really as some ppc and phones dont support it unless you pay for a player
    CdR
  2. #12
    Oct 2003
    Copenhagen, Denmark
    I think the image ref that uses the map needs to be put before the actual image map definition.
    Not doing carpc anymore
  3. #13
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    You can also just use remote desktop to connect to the CarPC with your PocketPC, IF you are running XP Pro, XP Media Center edition, Vista ect. on the CarPC as described HERE
    The major advantage being, no having to program a new interface in any way.
    You would also probably want to run a utility / change the display properties to view the screen in landscape mode.
    With a registry hack, it is also possible to RD into the computer, and leave the other user logged on. This would run a second instance of RR under the other user. I have never tried this, but it should work. If not, it would just put the carPC monitor onto the logon screen, and when done just tap the screen to log back in from that screen, and drop the PPC connection.
    My Fiero Build Thread
  4. #14
    Feb 2004
    Manchester
    ok, I have looked at remote desktop but thats crapo as you cant fit it all on one screen if you use windows rdt it locks you out of the main screen, you need some sort of terminal services on your pda / phone, this is why I've gone for the webbrowser, anything that can look at a webpage and control your rr.. PSP etc..
    The last problem I'm having is that everytime I click on link (button) on my skin it reloads the page.. Remember I'm coding the server so I can change commands coming in, but how do I stop the browser waiting ?
    CdR
  5. #15
    Apr 2005
    Queens, New York
    subscribed.... this seems very interesting cant wait to see the results
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  6. #16
    Feb 2004
    Manchester
    give me two ticks and I will post alpha1.0, again very alpha version but you will get the idea....
    brb
  7. #17
    Feb 2004
    Manchester
    ok, alpha version ready for you to play with...
    attached, please read the instructions
    CdR
    Attached Files Attached Files
  8. #18
    DCS
    DCS is offline
    Jan 2005
    Winfield, KS
    I have been using a program called total input, which lets you control your pc with a pda. (I use it With media Engine but should work fine for RR)
    They have a free version here:
    http://www.xronox.com/XronoxSite/TotalInputInfo.aspx
    ---the free version lets your ppc act as a wireless keyboard/mouse
    They also have an "elite" version..which will let you create your own buttons...skins..etc. for specific apps.
    check their site for more info.
  9. #19
    Feb 2004
    Manchester
    Thanks for the link m8, but I'm after installing no software on the client at all, all control is done directly though the web browser which are on most bluetooth / wifi units, does the DS have a wifi browser ?
    CdR
  10. #20
    Apr 2005
    Queens, New York
    Cant laod it...it says i need MSWINSCK.OCX. I will dl that file now and see what happens
    OK Now when i try to load it, it says
    prjWebServer
    Runtime-error '429'
    ActiveX Component cant create object
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. Using a Pocket PC for IR remote for CARPC
    By NightHunter in forum Software & Software Development
    Last Post: 02-26-2004, 04:30 PM
  2. pocket pc control?
    By meyer64 in forum Software & Software Development
    Last Post: 09-28-2002, 09:40 AM
