Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 59
Thread: Pocket PC Remote for RoadRunner ?
  1. #21
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    ya might need to register that ocx file before using it
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
  2. #22
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by Cheekz185 View Post
    Cant laod it...it says i need MSWINSCK.OCX. I will dl that file now and see what happens
    OK Now when i try to load it, it says
    prjWebServer
    Runtime-error '429'
    ActiveX Component cant create object
    Sounds like your roadrunner isnt installed right, you running vista ? Its using the roadrunner com object..
    ok update, added some error handling and the ability to change the web port
    CdR
    Attached Files Attached Files
  3. #23
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    CDR, I feel for you man! Doing something on a HTML page, is very hard to do without reloading the page. You can overcome this by using frames/iframes, hidden frames, and ASP. I ran into this problem a few years ago, when I set up all of my pages for my Home Automation system. The intent was the same exact thing, to be able to control it from any web browser on any device. Allowing me to turn lights on and off, check the status of the house, garage door, voice mails and all that fun stuff.
    I set this all up so long ago, that I just went back to look at the code, and it is like a foreign language to me.
    I do remember it has to be done in asp, and the command has to be processed by a hidden frame/page to trick the current page to stay where it is. You can also make the hidden page, change out an image on the main page when it is called ect. The ASP part is needed, as that can do a "Check" to see what buttons was used to call the page using typical IF/THEN/ELSE logic processing.
    My Fiero Build Thread
  4. #24
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Are you looking to perform an action using an image map? If so, you were close. Here is an example line of code within the image map block to accomplish it.
    <area href="vol+" shape="rect" coords="123, 258, 236, 313" HREF="#" onClick="HandleClick()" onMouseout="HandleMouseOut()" onMouseOver="HandleMouseOver()">
    The HandleClick(), HandleMouseOut(), HandleMouseOver() are my javascript functions that are called when the event occurs.
    Hope this helps...
    Quote Originally Posted by CdRsKuLL View Post
    ok I need some help with the html stuff, never really got on with it.. what I'm after is sending a command to the server via a hyperlink, with the actual browser not doing anything.. attached is a quick skin I did so you can see what I'm after..
    cheers
    CdR
    Code:
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
    <title>RR Webcontrol</title>
    </head>
    <body topmargin="0" leftmargin="0" rightmargin="0" bottommargin="0" marginwidth="0" marginheight="0" bgcolor="#000000">
    <p><map name="FPMap0">
    <area href="vol+" shape="rect" coords="123, 258, 236, 313">
    <area href="vol-" shape="rect" coords="4, 262, 123, 312">
    <area href="next" shape="rect" coords="173, 172, 233, 216">
    <area href="prev" shape="rect" coords="5, 170, 70, 216">
    <area href="play" shape="rect" coords="115, 135, 171, 241">
    <area href="stop" shape="rect" coords="68, 139, 111, 241">
    <area href="audio" shape="rect" coords="6, 8, 79, 62">
    <area href="video" shape="rect" coords="82, 7, 161, 63">
    <area href="gps" shape="rect" coords="164, 6, 232, 60">
    <area href="phone" shape="rect" coords="6, 62, 79, 122">
    <area href="radio" shape="rect" coords="79, 66, 161, 122">
    <area href="weather" shape="rect" coords="166, 63, 233, 122">
    </map><img border="0" src="skin.jpg" width="240" height="320" usemap="#FPMap0"></p>
    </body>
    </html>
    and the skin to match..
    ta
  5. #25
    FLAC alti's Avatar
    NY
    i have not been using rr, but i wanted to chime in here on the conceptual level since i have been working on something similar (not html)
    first have you found the ppc and smartphone sdk's for visual studio? they have an amazing api for controlling the phone using managed code, and it is chock full of example code.
    second, I like the http control idea, but more from the perspective of having a public ip for controlling it from anywhere. I think bluetooth would work better for this.
    lastly, addressing your question about avoiding refreshing, the best solution would be to use javascript's httpRequest object to send xml back and forth (ajax) but this is very hairy on the mobile browsers, even opera, which supports javascript, on pocket ie, forgetaboutit.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  6. #26
    Feb 2004
    Manchester
    Quote Originally Posted by bambam View Post
    Hope this helps...
    If my ppc supports javascript thus might ve what i#m looking for, can you show more code ? give me vb / vb.net / php / flash then I wouldnt have a problem..
    Quote Originally Posted by JohnWPB View Post
    I assume I would need the server I'm doing to support asp which would mean more coding
    Quote Originally Posted by alti View Post
    more info again please :-)
    need my hand holding
    cdr
  7. #27
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Well don't know about everybody else but after download the alpha I'm able to control RR with it (making it go to the audio menu,video,next etc... This looks like the html control for FP.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  8. #28
    Feb 2004
    Manchester
    :-) good old MC, yep it works, just a delay over wifi to load the picture up again.. I might of thought of a solution, just need to test it out.. O btw you need to set your clock right in rrconfig.. lol Still need to add a auto-start and start minimize.. also would like to get some feedback to the html page.. ie volume ammount / mute / play status etc.. all bove my html coding and its defo not another langauge I intend to learn
    CdR
  9. #29
    FLAC alti's Avatar
    NY
    first check out this
    http://www.microsoft.com/downloads/d...DisplayLang=en
    if you have not already
    and there is a great set of videos to help you get started here
    http://channel9.msdn.com/Showpost.aspx?postid=209122
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  10. #30
    Dec 2004
    Upstate New York
    cdr
    Sure. Tell me exactly what you are trying to accomplish.
    NO, you don't want asp. That requires the IIS server to be running. ASP is just a tagged lanuage that needs to be interpreted. Running a server on a carpc seems like way too much overkill. PHP is the same thing.
    VB "compiles" to p code which is kinda like glorfied interpreting but it has already been pre-compiled and needs the vb6 run time library. Works well for a stand alone app.
  1. Using a Pocket PC for IR remote for CARPC
    By NightHunter in forum Software & Software Development
    Last Post: 02-26-2004, 03:30 PM
  2. pocket pc control?
    By meyer64 in forum Software & Software Development
    Last Post: 09-28-2002, 08:40 AM
