Page 6 of 6 FirstFirst 123456
Results 51 to 59 of 59
Thread: Pocket PC Remote for RoadRunner ?
  1. #51
    Apr 2005
    Queens, New York
    oooo ok, cuz yea i noticed that on my ppc you cant get it to work with creating a com port.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  2. #52
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    ok, good news from Zorro, hes going to be allowing owners of a phonocontrol license to use the phocoadapter software seperate, you will need to load a file onto your ppc which will hold a special license key based on your imei serial number and your phonecontrol license.
    I will be posting more info soon I hope in here and on my site on how to install and get it working.
    CdR
  3. #53
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    What a top man Zorro is.... Will he be selling new licenses for those that dont have it - at least for the PPC client ?
    Terran
  4. #54
    Feb 2004
    Manchester
    Hi m8, I'm sure he will be able to sort something out.. but I'm unsure if he will be offering support on the phocoadapter.. saying this as long as it works.. it works :-)
    I will let you know more details as soon as I've chatted with him.
    CdR
  5. #55
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Quote Originally Posted by CdRsKuLL View Post
    CdR
    Which phocoadapter version did you use. I tried them all. I worked with Zorro on my HP 6515/WM2003SE for weeks and could not get it stable. I have a registered version. When I used your standalone all it would do was recycle the initalizing com attempt.
  6. #56
    Feb 2004
    Manchester
    Hi m8, I'm using the latest one thats with centrafuse at the moment. Just working out a license problem at the moment with him.. the adapter is working great.. + I've installed some free software from emoze – Free Push email, mobile email software for mobile devices. that links to my main machine and pushs email / tasks / contacts etc from my main machine to my phone.. works great :-)
    CdR
  7. #57
    FLAC sama's Avatar
    Feb 2006
    London, UK
    an intersting development indeed
    Javascript is the answer, and using an AJAX approach.
    what you would do in javascript is keep a socket open, and that would respond to events by fililng parts of the html document it's sitting on.
    the webpage can then dumbly just send requests without having to refresh, and the resopnses coming back through the javascript socket, would change the document wihtout it being reloaded.
    of course, you can get flash for the pcc, and use that instead!
    Hi m8, yeah I've been using zorros phocoadapter which works great, just closes itself after afew mins. CdR
    I've got the same issue, only I've not had time for my carpc these days
    more info here:
    IEMobile Team Weblog : AJAX on IE Mobile
  8. #58
    Feb 2004
    Manchester
    Thanks Sama, just put this on hold for the moment, got so many other projects on the go at the moment.. I'm happy for someone to knock a quick example together of either a .js file or something .. I can code the webserver to accept any command / request.. or even send info once a second like trackname , number , volume.. etc just I trying to get my FU skin upto a standard before O go on hols in 3 weeks..
    ~CdR
  9. #59
    Jan 2004
    NYC
    ~CdR
    did you ever get to finish this? I havent had a carPC in awhile, but i would love to use RR as my frontend for my music playback on my HTPC.. and use my UMPC for control..
    so basically install RR on my HTPC, use my UMPC as the remote
    [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
    [iGmon]
    Download MP3 MixTapes
  1. Using a Pocket PC for IR remote for CARPC
    By NightHunter in forum Software & Software Development
    Last Post: 02-26-2004, 03:30 PM
  2. pocket pc control?
    By meyer64 in forum Software & Software Development
    Last Post: 09-28-2002, 08:40 AM
