Results 1 to 6 of 6
Thread: Visualization always on in a .skin??
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    ok here is my latest problem..
    has anyone succeded in making a visualization always ON in a .skin??
    what i mean is i want the visu to be on no matter what in the speciffic .skin.
    the thing is that the VISU command toggles visualization ON & OFF, so there is no command to use so i can make sure the visual is surely loaded.. so actually RR is not aware if the visu in ON or OFF!!
    I tried the setting in winamp to always start visual. when playing, but it is started allright but not embedded correctly untill a VISU command is sent (twice that is in the case it is allready started - one to turn it off and one to turn it on and embed it)
    I need to have the visu ON in many skins as well.. and this procedure has to be made for each and every skin whenever it is loaded..
    for example if you have the visu ON in a skin then change to a another skin and want the visu ON as well you would have to press the VISU button twice in that skin aswell and so on.. so no way to have a visual on for every skin..
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Just have a command like this when you change skins.
    Like from your main to your audio skin.
    "AUDIO||VISU||VISU"
    This loads your audio skin and pushes the button for you twice.
    Apr 2006
    Greece
    that will slow changing skins down a lot..and i am not sure it will work always..
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    try this after you start VISU 1 time.
    maybe
    "ONSKINSTART","VISU"
    "WHATEVER","LOAD;SKIN.SKIN||RUN;;AVS"
    like
    "AUDIO","LOAD;Audio_Player.skin||RUN;;AVS"
    there is no program to run just window name
    EDIT; Could not get it to work.
    2001 S10 ZR2
    Chucks Skin - to old
    Apr 2006
    Greece
    i just wished there was a way for visualizations to be part of the skins... and not embedded..i wonder why there are no FLASH visualizations out there..
    what might work is (i am using the spectrum analyzer vis satan...or something) is to have the visual always on in winamp and started in specific coordinates(the plugin offers that) then just clip an area in all my skins..which will show what is behind.. it actually works..the onle problem is a tiny tiny frame around the visual (not the winamp frame a tiniest one) but it is ok i guess.. and another is that if you accidently move the visualisation then it will move..baaad.. i fixed that by making the plugins INI read only !!!!!!so it won't write new coordinate values ahahaha nice e?
    Apr 2006
    Greece
    what might work is (i am using the spectrum analyzer vis satan...or something) is to have the visual always on in winamp and started in specific coordinates(the plugin offers that) then just clip an area in all my skins..which will show what is behind.. it actually works..the onle problem is a tiny tiny frame around the visual (not the winamp frame a tinier one) but it is ok i guess.. and another is that if you accidently move the visualisation then it will move..baaad.. i fixed that by making the plugins INI read only !!!!!!so it won't write new coordinate values ahahaha nice e?
    EDIT: problem solved..
    1. this vis plugin is wonderful..customizable 120%..
    2. VISU||VISU actually works nice, for every skin..
  1. Replies: 13
    Last Post: 08-30-2007, 09:27 PM
  2. request: exclude command on .skin
    By liquid_smoke in forum Road Runner
    Last Post: 11-03-2006, 06:41 PM
  3. Disable Album Art When Visualization Enabled
    By MoonShiner in forum RR Skins
    Last Post: 04-17-2006, 12:47 PM
  4. How to set Winamp visualization?
    By kebab in forum Road Runner
    Last Post: 08-31-2005, 05:23 PM
  5. *Idea* OBD-II Visualization
    By cadence117 in forum Software & Software Development
    Last Post: 09-29-2004, 08:34 PM
