Results 1 to 10 of 17
Thread: Strange RR problem with auto day/night switching
    Dec 2005
    I have auto skin and gamma switching enabled in RR, setup using an alternative config program posted on this forum. Settings in RR.ini are like this -
    gammamode=2
    autogammamode=1
    autoskinmode=1
    gpsgammamodeoffset=0
    gammadaytime=08:00
    gammanighttime=18:00
    gammaday=0:0:0
    gammanight=-50:-50:-50
    The auto switching is setup to change between day and night settings at the set times. However, whenever RR changes between the day and night skins and gamma, the screen becomes corrupted, and a large grey rectangle appears in the top left of the screen (see screenshot below). This disappears if you change the RR screen (e.g. to music), but when you minimize RR it's still there, and comes back to the top every time the day/night change is activated. When you close RR, the rectangle disappears, otherwise no amount of minimizing RR or refreshing the desktop will get rid of it. The letters "RAN" appear in the middle of the rectangle, in yellow text.
    Any ideas how to get rid of this window? It seems as if the VB code is opening up a form it shouldn't be.
    See the attached screenshot for a picture of what I mean.
    Dec 2005
    Having had a brief look at the RR source code, the form called "frmSkin" looks like the most likely culprit - it's grey, and the correct size.
    Any ideas why this would randomly appear?
    Screenshot -
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    got the same prob also. good so it just wasnt me.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Dec 2005
    Quote Originally Posted by Enforcer View Post
    This may be way of base, but check to see if you have a wait.skin.
    Yup - I'm using BAV2 as my day skin and BMV2 as my night skin - both have a wait.skin
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by hellodave View Post
    Are you sure you have set the Config up correctly ? Are you using the Skippy config, and are you trying to change the Gamma or the Day/Night skin ?
    See this thread and in particular my post #22
    Question. Autoswitching Skins...
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
    Dec 2005
    Quote Originally Posted by wizz View Post
    I'm using the same config as you show in that thread (I assume it's Skippy's?). I've got it set to change both Gamma and skin fully automatically, currently via GPS.
    Nov 2004
    Leicestershire UK
    Yes it is Skippy's. Why don't you try just one, say changing the skin and not the gamma because that's the most important function, and see if that stops the problem.
    I'm using BMV2 and do just that, and I have no problems with it. I use the same BMV2 skin for both day and night, one being re-coloured for day use.
    Dec 2005
    I do need to change both skin and gamma, otherwise everything is too bright at night!
    I'm trying a different workaround at the moment - I'm not sure what frmSkin.skin is used for, but I've resized it to nearly nothing in VB and recompiled RR. The resulting program seems to run OK so I might try it out over the next few days and see what happens. It's not exactly a brilliant solution, but it might suffice until someone finds out what (if anything) is wrong with the day/night switching code.
    FLAC djmickyg's Avatar
    Feb 2004
    i had the same issue..
    i ended up tunrning it off and going back to gammacontrol. which also does freedrive.
  1. RR 03-06-06 AVS problem
    By mauri in forum Road Runner
    Last Post: 04-09-2006, 12:40 AM
  2. Any news about my strange problem? RR and Girder
    By slimmegane in forum Road Runner
    Last Post: 07-11-2005, 12:52 PM
  3. Auto load FD when RR starts up
    By tolisn in forum Road Runner
    Last Post: 07-08-2005, 05:30 PM
  4. RR loading screen when I press Day/Night..
    By Nighcrawler in forum Road Runner
    Last Post: 05-18-2005, 11:09 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
