I am having the same issue, did you get it sorted out?
I cant figure this out (screen shots below).
When I click the sirius button in either skin RR shows the XM banner and my mp3 play list and does not tune sirius channels.
My sirius connect is on com5 and works with sirius recorder.
Steps I have taken.
upgraded RR using auto updater.
uninstalled RR and installed manually
uninstalled RR and auto-installed/updated
deleted and re-installed skins each time
used both the usb driver that came with sirius connect and the latest from the web
updated flash player
updated windows
HELP!
Intermission....
A couple things you did not mention. Did you change the settings in RRConfig? You have to put a 0 for XM port in there, and the port that your Sirius device is on for Sirius.
Secondly, you need to open the menu.skin in notepad, and find the line with XM in it, and change it to "SIRIUS".
For the BMV2 skin it would be this line:
and change to this line:Code:B06,11,305,339,106,"XM",""
Hopefully that will get you guys going.Code:B06,11,305,339,106,"SIRIUS",""
My Fiero Build Thread
Yes, XM is set to 0 and Sirius is on com 5 and set that way in config and confirmed in ini. I tried renaming the xm skin to sirius at one point and that just changed the xm logo to the sirius logo.
OK, That totally worked and now RR totally ROCKS!! Changing the menu.skin fixed it.
Was that a total newb mistake on my part or what? I didn't see that documented anywhere.
One thing though, now the play list is correct and it friggen works so I dont really care too much but the sirius logo is gone from the upper left.
JohnWPB -Thank you so much!!! I had all but given up. Spent a whole weekend working on this.
