For some reason Blue's config defaults to 3 screens on the limit setting, this should be blank or a higher number like 10 by default.
Printable View
@guino and sonic, i just downloaded the 12/13/07 binary and the dayskin/nightskin commands still close iguidance. i have embedapplist=iGuidance and screenlimit=10 in my rr.ini file. also, did either of you happen to see my post about the bug about the winamp pause/lower volume on iguidance speech feature?
thanks guys
Alright guys, I spend some time look into this issue. Well, there was a fixed I send to Sonic a while a back. The code is in latest OFFICIAL release (11/02/07). That will take care of MANUAL skin change and reload problem.
The latest problem you guys found is in the auto skin switch by GRAMMA or DAY/NIGHT setting. I fix that too. The fix is similar to previous one. This one in in Exec_SkinChange procedure (ModRoadRunner.bas). I send the code to Guino shortly. If anyone can't wait and have a way to compile the code, here is the fix. Note that I just cut and paste from the previous fix. ;).
ModRoadRunner.bas, Exec_SkinChange procedure.
Change from
change toCode:'Unload All forms in order
t = UBound(Menus)
While t >= 0
#If Mappoint Then
If Menus(t).Tag = "mappoint_gps.skin" Then: s = "MapPoint"
#End If
Unload Menus(t)
Set Menus(t) = Nothing
t = t - 1
Wend
Let me know if there is problem with that. ;).Code:
t = UBound(Menus)
While t >= 0
#If Mappoint Then
#End If
'Modified by MatrixPC: Keep GPS running while switch skin.
If (Len(Menus(t).AppName) > 0 And Len(UseVars("EmbedAppList")) > 0 And InStr(1, UseVars("EmbedAppList"), Menus(t).AppName) > 0) Then
HideWindow Menus(t).AppName, True
Else
If CloseAPPs And Menus(t).AppName <> "" Then CloseWindow Menus(t).AppName
Unload Menus(t)
End If
t = t - 1
Wend
It's probably already in the 12/6 release.
But since no one mention about the fix in that release and the source isn't available yet to verify that it's in.
i have the latest 12/13 release and the problem still occurs.
Still happening for me also with the 10/08 build. Anyone know a workaround?
