Results 1 to 10 of 10
Thread: Video freezes after RR upgrade
    Oct 2005
    Hello.
    I have searched the forums and tried all the fixes that I can find that may be relevant but I still have this problem.
    Just to let you know, EVERYTHING was working ok before the update.
    I just updated RR to the latest version (04-11-07) and now when I try to play a video it starts to play the last played video as normal. When I click on any button the program freezes with CPU at 100%.
    The mouse still works but nothing that you click on works. I have to shutdown RR using Task Manager.
    All the videos are ones that were working fine before I updated RR.
    I have tried deleting videos.m3u, updating codecs, deleting the video files, re-installing the new RR.
    I have tried this in several skins including BMV2 and it does the same thing everytime.
    If no one can help on this can anyone point me to where I can download an earlier version of RR. I think I was using the one from around June 06.
    Many thanks in advance
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    this is usually a codec issue.. try deleting videos.m3u and switching the built-in player option on/off.
    Ride Runner RR's Myspace
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    I was just getting ready to post a similiar problem. However if I wait long enough (about a minute) it comes back.
    Click Video
    Video starts to play
    Click 'folder' to select a different video
    Video browser partially shows up (no videos listed) and computer is unresponsive. (FULL) is on the top left of the screen.
    Wait a minute.
    Computer starts to respond and the video list shows up.
    Video continues to play (can hear it).
    If I select another video it starts to play normally.
    This happens regardless of video type (normal mpg or mpeg4--acc/h.264 videos) and both with the built in player and MPC. It happens regardless of skin as well. New install of RR. If I move the old RR folder back, it works perfect.
    Hope this helps.
    FYI, everything else is working great in the new RR.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    Oct 2006
    small town nebraska
    In the interest of figuring this out. I reinstalled everything again....and made changes to the config one at a time until the problem surfaced. In my case it seems in the music section Show ID3 Browse is causing the problem. When it's turned on has the above symptoms, when it's off it works perfect.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Do you have "MediaInfo.DLL" installed by any chance ?
    Oct 2006
    small town nebraska
    I do, it must be part of the installer. Just delete to remove?
    thanks,
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try the new version first, but check this one out:
    video problems under new rr
    Oct 2006
    small town nebraska
    Where do I get the new version of mediainfo.dll? (That thread seems to be what I'm having problems with).
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The release post for version 9-2 has a link to it.. but try 9-9 first. In any case, you can always just rename/delete it.
    Oct 2006
    small town nebraska
    9-9 Works great with Show ID3 Browse turned on/off.
    thanks guino.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. Video problem with usedualmon
    By Goddy in forum RR Bug Tracker
    Last Post: 10-26-2006, 12:07 PM
  2. Video problem (maybe) RR 9-5-06
    By vinzer in forum Road Runner
    Last Post: 09-09-2006, 01:29 AM
  3. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  4. RR Video does not play all videos
    By Lyzdog in forum Road Runner
    Last Post: 01-18-2006, 08:23 AM
  5. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
