Results 1 to 7 of 7
Thread: RR Losing ID3 Tag data when opening .exe's from removeable media...
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    v4-11-2007
    I had this wacky idea of putting rainlendar on my thumb drive so I don't have to keep sync'ing the calendar files b/w different computers.
    After opening rainlendar, or any stand alone app, from the thumbdrive, all the MP3 ID3 Tags revert to their filenames in RR. The audio library display seems unaffected. Only the playlist and labels lose their ability to display ID3 tag info.
    Have to reload RR to get them to display properly.
    FYI.
    You rule guino!
    RR#1!
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That's a wacky but clever idea... I am puzzled however as to why it would affect RR's playlist.. Unless you're running RR on a different folder or something messed with RR.INI, TagCache.ini (Both in RR's folder) OR Winamp.m3u (in winamp's folder).. this shouldn't be happening.
    Ride Runner RR's Myspace
    Aug 2006
    Sun Diego
    Well, RR is installed in the default directory: C:\Program Files\Road Runner\
    The command line used to bring up Rainlender is this:
    ExecTBL.ini
    "UTIL04A","LOAD;$UTIL04appskin$;RUN;$UTIL04apppath $;$UTIL04appname$"
    skin.ini
    UTIL04L=Rainlendar
    UTIL04appskin=Rainlendar.skin
    UTIL04apppath=H:\Program Files\Rainlendar\Rainlendar.exe
    UTIL04appname=Rainlendar
    where H:\ is the thumbdrive.
    If I run Rainlendar off the C:\ drive, all is well and I don't experience the loss of ID3 tag display information.
    Same thing happens if I run rainlendar using:
    "LOAD;Rainlendar.skin;RUN;H:\Program Files\Rainlendar\Rainlendar.exe;Rainlendar"
    guino's Avatar
    Nov 2004
    Toronto, Canada
    can you try something like "notepad" to see if it happens ? It's hard to believe it's something RR's doing..
    Aug 2006
    Sun Diego
    Okay, I tried running notepad and rainlendar off a thumbdrive on my two dev machines, plus my carPC. It seems to only do it on one dev machine running Win NT 2000.
    Doesn't seem to be affecting RR on XP SP1 & 2.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That's even weirder... using the same winamp on win 2000 ?
    Aug 2006
    Sun Diego
    Yup. Same winamp.
  1. Renault "Tuner List" Head Unit/CD changer hacking - Controls
    By Vicne in forum Hardware Development
    Last Post: 12-29-2015, 01:33 AM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. Replies: 3
    Last Post: 11-23-2006, 11:14 AM
  4. Windows Vista W/nView!
    By 97GST in forum Operating System Optimization
    Last Post: 04-01-2006, 09:46 PM
  5. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
