Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: idrive & Iguidance help!
  1. #11
    Aug 2007
    Thanks Enforcer! I was going into the RRConfig from the start menu, I was not aware of the config in RR. That solved that problem!
    but I still can't get my GPS to work Inside roadrunner, I can't seem to connect my GPS Reciever (even though it says 9/10 by the top satellite). It always says "Off-Road" . But if I were to load up IGuidance outside of windows, it would work perfectly fine. Any Ideas?
    Thanks in advance
  2. #12
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    RoadRunner is hogging the GPS.
    either
    A) remove the setting from RRConfig for the COM port, ie don't have it to the port that your GPS mouse is in.
    or
    B) get a com port splitter, Xport for example, and set that up so both RR and iGuidance can have access to the GPS. (recommended option)
  3. #13
    Aug 2007
    wow thanks for the fast reply Enforcer! i will give it a try today
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 09:29 AM
  3. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  4. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  5. Hacking Iguidance
    By Peoples in forum GPS
    Last Post: 08-28-2005, 07:40 PM
