Results 1 to 6 of 6
Thread: Milkdrop flashes on fading album art change
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    Anyone else have this problem? Use milkdrop as the visualization and enable fading album art. When the song changes, the visualization disappears as the image changes and reappears a split second later. It works smoothly once in a while though. This doesn't happen when using AVS.
    Tried winamp 2.95 and winamp 5.13.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It's just a side-effect of how milkdrop is embbeded (which is just a window placement over RR). Milkdrop doesn't behave nicely when we embed it like AVS (which is what would solve the problem), so there's not much of a fix for it.
    Ride Runner RR's Myspace
    Mar 2007
    Thanks for the reply!
    How about making the 'fadeimages' variable changeable during runtime? Then I can play around with the commands to disable the image fading when the visualization is started.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This is exactly what I was going to post about...
    I did make changes that turned off both the highligh follow song and updating the album art if I had the visu turned on b/c on slower machines (M10k) and the visu covered either the art and/or the playlist it would do this, and it just makes it not look good when say playing a dj mix with 10 30sec tracks in a row.
    @guino - I beleive that you could easly add/change this to how I described above, I added a visu varaible and when RR goes through the sceen update section, if the visu var is true/false then it allows/denies the update of those two things when updating. Work great on my setup. It just took some time to figure out where excactly the updating was occuring.
    example, this is my visu code from my execTBL.ini
    "RUNVISU","SETVAR;VISURUNNING;1||SETVAR;LISTFOLLOW SSONG;FALSE||SETVAR;UPDATEALBUMART;FALSE||VISU"
    "STOPVISU","SETVAR;VISURUNNING;0||SETVAR;LISTFOLLO WSSONG;TRUE||SETVAR;UPDATEALBUMART;TRUE||AUDIO"
    And this was the added/changed RR code
    Code:
    modRoadRunner - UpdateScreen (~line 3632)
            'If Has next song ready, play that instead
            If NextSong > -1 Then WinAMP_SetPlaylistPos NextSong: WinAMP_SendCommandMessage WA_PLAY: NextSong = -1
            'If need to set new selection (follow option) - changed by Blue ZX3
            If CBool(UseVars("listfollowssong")) And F.ShowPL Then
                F.PL.Value = WinAMP_GetPlaylistPos
                F.PL.CenterList
            End If
            If CBool(UseVars("listfollowssong")) And F.ShowDL Then
                If F.DL.Path = Left(PlayList(WinAMP_GetPlaylistPos), Len(F.DL.Path)) Then
                    s = LCase(PlayList(WinAMP_GetPlaylistPos))
                    For t = 0 To F.DL.Max
                    If s = LCase(F.DL.Path + F.DL.GetItem(t)) Then
    modRoadRunner - UpdateScreen (~line 3658)
    	'Get Current Song's ID3 Info (If not using ID3, it will cancel out by itself)
            CurrentTAG = GetSongTitle(PlayList(WinAMP_GetPlaylistPos), True, "%artist%" + Chr(0) + "%album%" + _
                                        Chr(0) + "%tracknumber%" + Chr(0) + "%genre%" + Chr(0) + "%year%" + Chr(0) + "%title%")
            'Control albumart update upon screen update - Added by Blue ZX3
            If Not CBool(UseVars("updatealbumart")) Then GoTo NoPic
            'Prepare Folder to look for Album art
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Mar 2007
    I'm thinking it would be easier to just disable the album art changing when milkdrop has started (if the fading is the only thing causing the flash). That way, skins that display the cover art and visu simultaneously still kinda work.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    With how I did it, it would be on a (per skin/user) basis. Or in other words, if you don't want to use it then you would just not use it, and it wouldn't change the way the official release's work..
    Just about anything thing that I do, I have/make an option for the setting...off/on
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Album art downloader
    By hijinks21 in forum Software & Software Development
    Last Post: 07-20-2006, 10:56 AM
  2. Album art problem
    By lucianop in forum Road Runner
    Last Post: 06-04-2006, 02:00 AM
  3. Album art browse bugs?
    By froop in forum RR Bug Tracker
    Last Post: 12-11-2005, 01:02 AM
  4. album art in id3 causes improper read
    By hateeecs in forum CF Bug Reports
    Last Post: 09-06-2005, 01:34 PM
