Results 1 to 5 of 5
Thread: Gonna have to bear w/ me on this one...
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    To start, here's an ONSKINSTART that's in my MMIv2.0 skin:
    skin's ExecTBL.ini
    Code:
    "ONSKINSTART","STARTUPFILEBR||STARTUPIGCONFIG||WRITEUTILICON||SAVEDRIVECONFIG3||SETTHEME||WRITEWEB||LOADLATESTFLDATA||LOADLATESTMLDATA"
    I'm not not gonna bore you w/ the code for each command as they are quite lengthy. The summary of each command is a series of SAVETOSKIN, WRITETOFILE, ADDTOFILE commands to various *.skin and *.txt files that is used in my skin using the INC command line with tons of variables defined in skin.ini
    So here is the oddity that I am experiencing.
    Let's say you initally start RR with MMIv2.0 as the starting skin. It'll follow the ONSKINSTART command as it should writing to each file w/ details to complete various skin files when loaded.
    If you use skin browser to switch skins, say BMV2, even though ONSKINSTART is defined only in the MMI skin's ExecTBL.ini, it'll run MMIv2.0's ONSKINSTART command and write the files in the BMV2 skin folder.
    I don't now if that was intended or not, but should this be happening? I mean, shouldn't those ExecTBL commands stay only w/in the skin? I'd hate to think that I'm cluttering up another skin folder w/ my startup files.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    definitely shouldnt and doesnt happen with my skin . As long as that exectbl.ini is in a skin folder its ignored by rr unless that skin is loaded. Are you sure that you dont have it in the rr exectbl.ini and dotn realize it .
    Live mp3Car Facebook Chat
    Aug 2006
    Sun Diego
    LOL! I'm absolutely sure it's not the $rrpath$ ExecTBL.ini.
    And my skin's ONSKINSTART defined in my skin's ExecTBL.ini is definitely writing my startup files to other folders once I move away from MMIv2.0 to other skins using skin browser.
    Aug 2006
    Sun Diego
    Quote Originally Posted by Enforcer View Post
    maybe you need to show us the code for at least one of the commands that doing it.
    Okay.
    skin.ini
    Code:
    UTIL01icon1=IMG,178,130,45,43,"$UTIL01icon$",OFF
    UTIL01icon2=IMG,178,130,45,43,"$UTIL01icon$",ON
    UTIL01icon3=IMG,178,130,45,43,"$UTIL01icon$",DOWN
    UTIL01icon4=IMG,178,130,45,43,"$UTIL01icon$",EMPTY
    UTIL01icon5=IMG,178,130,45,43,"$UTIL01icon$",OUT
    UTIL02icon1=IMG,178,177,45,43,"$UTIL02icon$",OFF
    UTIL02icon2=IMG,178,177,45,43,"$UTIL02icon$",ON
    UTIL02icon3=IMG,178,177,45,43,"$UTIL02icon$",DOWN
    UTIL02icon4=IMG,178,177,45,43,"$UTIL02icon$",EMPTY
    UTIL02icon5=IMG,178,177,45,43,"$UTIL02icon$",OUT
    UTIL03icon1=IMG,178,224,45,43,"$UTIL03icon$",OFF
    UTIL03icon2=IMG,178,224,45,43,"$UTIL03icon$",ON
    UTIL03icon3=IMG,178,224,45,43,"$UTIL03icon$",DOWN
    UTIL03icon4=IMG,178,224,45,43,"$UTIL03icon$",EMPTY
    UTIL03icon5=IMG,178,224,45,43,"$UTIL03icon$",OUT
    UTIL04icon1=IMG,178,271,45,43,"$UTIL04icon$",OFF
    UTIL04icon2=IMG,178,271,45,43,"$UTIL04icon$",ON
    UTIL04icon3=IMG,178,271,45,43,"$UTIL04icon$",DOWN
    UTIL04icon4=IMG,178,271,45,43,"$UTIL04icon$",EMPTY
    UTIL04icon5=IMG,178,271,45,43,"$UTIL04icon$",OUT
    UTIL05icon1=IMG,178,318,45,43,"$UTIL05icon$",OFF
    UTIL05icon2=IMG,178,318,45,43,"$UTIL05icon$",ON
    UTIL05icon3=IMG,178,318,45,43,"$UTIL05icon$",DOWN
    UTIL05icon4=IMG,178,318,45,43,"$UTIL05icon$",EMPTY
    UTIL05icon5=IMG,178,318,45,43,"$UTIL05icon$",OUT
    UTIL06icon1=IMG,178,365,45,43,"$UTIL06icon$",OFF
    UTIL06icon2=IMG,178,365,45,43,"$UTIL06icon$",ON
    UTIL06icon3=IMG,178,365,45,43,"$UTIL06icon$",DOWN
    UTIL06icon4=IMG,178,365,45,43,"$UTIL06icon$",EMPTY
    UTIL06icon5=IMG,178,365,45,43,"$UTIL06icon$",OUT
    UTIL07icon1=IMG,178,130,45,43,"$UTIL07icon$",OFF
    UTIL07icon2=IMG,178,130,45,43,"$UTIL07icon$",ON
    UTIL07icon3=IMG,178,130,45,43,"$UTIL07icon$",DOWN
    UTIL07icon4=IMG,178,130,45,43,"$UTIL07icon$",EMPTY
    UTIL07icon5=IMG,178,130,45,43,"$UTIL07icon$",OUT
    UTIL08icon1=IMG,178,177,45,43,"$UTIL08icon$",OFF
    UTIL08icon2=IMG,178,177,45,43,"$UTIL08icon$",ON
    UTIL08icon3=IMG,178,177,45,43,"$UTIL08icon$",DOWN
    UTIL08icon4=IMG,178,177,45,43,"$UTIL08icon$",EMPTY
    UTIL08icon5=IMG,178,177,45,43,"$UTIL08icon$",OUT
    UTIL09icon1=IMG,178,224,45,43,"$UTIL09icon$",OFF
    UTIL09icon2=IMG,178,224,45,43,"$UTIL09icon$",ON
    UTIL09icon3=IMG,178,224,45,43,"$UTIL09icon$",DOWN
    UTIL09icon4=IMG,178,224,45,43,"$UTIL09icon$",EMPTY
    UTIL09icon5=IMG,178,224,45,43,"$UTIL09icon$",OUT
    UTIL10icon1=IMG,178,271,45,43,"$UTIL10icon$",OFF
    UTIL10icon2=IMG,178,271,45,43,"$UTIL10icon$",ON
    UTIL10icon3=IMG,178,271,45,43,"$UTIL10icon$",DOWN
    UTIL10icon4=IMG,178,271,45,43,"$UTIL10icon$",EMPTY
    UTIL10icon5=IMG,178,271,45,43,"$UTIL10icon$",OUT
    UTIL11icon1=IMG,178,318,45,43,"$UTIL11icon$",OFF
    UTIL11icon2=IMG,178,318,45,43,"$UTIL11icon$",ON
    UTIL11icon3=IMG,178,318,45,43,"$UTIL11icon$",DOWN
    UTIL11icon4=IMG,178,318,45,43,"$UTIL11icon$",EMPTY
    UTIL11icon5=IMG,178,318,45,43,"$UTIL11icon$",OUT
    UTIL12icon1=IMG,178,365,45,43,"$UTIL12icon$",OFF
    UTIL12icon2=IMG,178,365,45,43,"$UTIL12icon$",ON
    UTIL12icon3=IMG,178,365,45,43,"$UTIL12icon$",DOWN
    UTIL12icon4=IMG,178,365,45,43,"$UTIL12icon$",EMPTY
    UTIL12icon5=IMG,178,365,45,43,"$UTIL12icon$",OUT
    skin ExecTBL.ini
    Code:
    "WRITEUTILICON","WRITE01||WRITE02||WRITE03||WRITE04||WRITE05||WRITE06||WRITE07||WRITE08||WRITE09||WRITE10||WRITE11||WRITE12"
    "WRITE01","WRITETOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL01icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL01icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL01icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL01icon5$"
    "WRITE02","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL02icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL02icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL02icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL02icon5$"
    "WRITE03","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL03icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL03icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL03icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL03icon5$"
    "WRITE04","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL04icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL04icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL04icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL04icon5$"
    "WRITE05","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL05icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL05icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL05icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL05icon5$"
    "WRITE06","ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL06icon1$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL06icon2$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL06icon3$||ADDTOFILE;$skinpath$TOOLS2_EXT.skin;=$UTIL06icon5$"
    "WRITE07","WRITETOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL07icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL07icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL07icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL07icon5$"
    "WRITE08","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL08icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL08icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL08icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL08icon5$"
    "WRITE09","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL09icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL09icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL09icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL09icon5$"
    "WRITE10","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL10icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL10icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL10icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL10icon5$"
    "WRITE11","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL11icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL11icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL11icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL11icon5$"
    "WRITE12","ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL12icon1$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL12icon2$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL12icon3$||ADDTOFILE;$skinpath$TOOLS3_EXT.skin;=$UTIL12icon5$"
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  2. Gonna Order Parts very soon, LOOK AT THIS!
    By Power_nisse in forum Newbie
    Last Post: 07-17-2005, 04:25 PM
  3. Gonna go to the computer show today
    By lostreception in forum Off Topic
    Last Post: 05-15-2005, 12:38 PM
  4. Ok this is what I'm gonna do
    By CGTX24 in forum Newbie
    Last Post: 06-13-2004, 03:27 PM
  5. Ok,I'm gonna try The inverter but...?
    By Meoff in forum General Hardware Discussion
    Last Post: 06-22-2000, 02:56 AM
