Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Today is 07 Sept 2013 (GPStime)
  1. #11
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by guino View Post
    Oh -- and to be sure:
    gpsusadate=false does absolutely nothing -- only by removing the line you get different results.
    Well that should be fixed...ya its pointless to have a false setting if it doesn't change anything, but in these cases Y are some settings coded like this?? It falls under the inconsistant typical setting things. True = setting on, False = Setting off, not remove line to turn off setting...
    Well, when or IF it gets changed I'll change the config's setting too, as it was my understanding that setting it to false would not use it...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll fix it for next release. But I suggest to keep things simple.. if a setting is being saved to the default value, simply don't include it in the INI -- it's faster to parse it that way.
    Ride Runner RR's Myspace
  3. #13
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Gee...that would mean digging through the code(RR's) before the rr.ini file is read to see exactly what each setting's default setting is...and don't tell me to see the famous readme.txt...its too not up todate.
    Which reminds me that i'll still get around to getting you all the missing settings that i noticed...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    haha.. the readme is fairly up to date on what's "default" .. at least on the settings it lists (most of them) :P
  5. #15
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well according to my RR INI bible that was created out of doing the whole config project, I count like 17 missing settings.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #16
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    What are you talking about??
    And where is you notepad?? Sorry notepad doesn't have a spell checker... LOL
    Using the GPS time, would you like to be transported to future date of 2013.
    Please note that neither RoadRunner nor Guino is [hl]responisable[/hl] for any
    mal-causes of your actions from taking such a big leap in years.
    That spelling.
  7. #17
    MAH
    MAH is offline
    Newbie MAH's Avatar
    Feb 2007
    Quote Originally Posted by 2k1Toaster View Post
    Is this with the new 09/09/07 version?
    Yes this latest version is the one I used.
  8. #18
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Shreveport, LA
    Is the setting gpsusadate= , or gpsusdate=
    I had no reason to think it was misspelled, but I gave it a try and when I manually changed it to gpsusdate=true in my ini, it has seemed to work.
    Only problem is every time I save using the awesome RRConfig, I have to go back and manually change it again.
    Hope it works for others.
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
  9. #19
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Straight from RR's code(only one line in the whole code that points to that settings usage):
    DT(0) = "": DT(0) = UseVars("gpsusadate")
    And also listed in the Readme.txt(ini settings) is also gpsusadate.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #20
    guino's Avatar
    Nov 2004
    Toronto, Canada
    setting gpsusdate instead of gpsusAdate will make RR ignore that setting -- making it use the default (standard GPS time format), meaning, it's the same as removing the line.
  1. iDrive 2.20 Release
    By Enforcer in forum RR Released Skins
    Last Post: 08-03-2009, 05:03 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. News on the 07 version
    By netsuo in forum NeoCar Media Center
    Last Post: 11-06-2004, 10:01 PM
